F250 Brake Rotor Warranty?
Old 11-10-2005 | 09:13 AM
eyezlee's Avatar
Default F250 Brake Rotor Warranty?
I have a 2003 F250 PSD and the front rotors are warped. Does anybody know if this is covered under the standard 100,000 mile warranty?
If not under warranty, then I think I'll go with the brembo rotor / hawk pad setup.
Thanks.
eyezlee is offline
Old 11-10-2005 | 09:43 AM
Scott's Avatar
Charter Member #30
Default Re: F250 Brake Rotor Warranty?
No they are not covered and I ended up doing the same thing you are about to do It's not worth messing with them, Ford will turn them on the vehicle if your under the 36k warranty but why bother they will heat up and warp again within the next month
I have Steps & Bubbles!
Scott is offline
Old 11-10-2005 | 09:45 AM
Sean H's Avatar
A to Z
nope..... i think brakes are the first thing on the list of things not covered..
Sean H is offline
Old 11-10-2005 | 09:47 AM
I dont think it is? I believe the 100k warranty is just drive train unless you have the extra bumper to bumper warranty.
If you take your rotors and pads to Robertson tire they will do the work for about $65. I called about a front brake job on my 2002 and they said to replace pads and turn rotors was about $150 but if I brought my own pads in it would only be $65 which to me is worth it.
Finman
FINMAN is offline
Old 11-10-2005 | 01:26 PM
birdog's Avatar
Not covered....After 2 sets i changed to NAPA rotors...never a problem since.
birdog is offline
Old 11-10-2005 | 01:45 PM
eyezlee's Avatar
Finman
Sweet. This is what I'm going to do. What rotors did you go with?
eyezlee is offline
Old 11-10-2005 | 01:53 PM
I havent done it yet. My rotors seem good so hopefully they will be able to just turn them. I dont think its ever had a brake job.
Finman
FINMAN is offline
Old 11-11-2005 | 08:17 AM
buck183's Avatar
Have you searched around on that "one" site with all of that "stuff" on it yet to check pricing on rotors?
Buck
buck183 is offline
Old 11-11-2005 | 04:27 PM
Registered User
All the dealer will do is turn them for you. They will do that until you're out of the 36K/mi. portion of the warranty- by then, they'll be too thin to turn further.
Buy a set of powerslots- not crossdrilled. The EBC green pads are great too
Chris Sunkin is offline
Old 11-15-2005 | 10:54 PM
klmken's Avatar
Motor only is covered to 100k.
klmken is offline
