Hitch Question
Old 11-11-2005 | 06:51 AM
Default Hitch Question
Are all hitch's, no matter what the brand or make, equal per class... In other words are all class I's rated up to 2500, all class II 4500, all class III's 7500, and so on, and its just a matter of brand you buy based on preference not strength, (above rates just an example), looking for all the hitch info i can get to make the right choice
Steve Jr
Boomer35 is offline
Old 11-11-2005 | 07:06 AM
CigDaze's Avatar
Default Re: Hitch Question
That is correct...to a degree. The DOT along with SAE sets the standards for minimum strength and performance requirements. Each and every hitch, regardless of brand will perform as expected to it's rated strength, by law.
However, some manufacturers use design load cases and factors of safety above and beyond the minimum. How much, who knows? Bottom line, if you get a hitch that meets or exceeds the load criteria for your towing situation you will be fine both towing the load, and will be covered in the event of an accident.
CigDaze is offline
Old 11-11-2005 | 07:25 AM
Thanks Nick-
My old man said to say hello and hopes your enjoying the boat
Steve Jr
Boomer35 is offline
Old 11-11-2005 | 07:43 AM
Where can i find each Hitch's rating, or can anybody just tell me...
Boomer35 is offline
Old 11-11-2005 | 08:14 AM
buck183's Avatar
Each hitch should have a sticker on it telling you it's rating.
There are generally two ratings on hitches. There will be a weight carrying rating, and a weight distributing rating.
Buck
buck183 is offline
Old 11-11-2005 | 08:22 AM
CigDaze's Avatar
Originally Posted by Boomer35
Thanks Nick-
Steve Jr
You're welcome, Steve, and a "Hello!" back at you guys.
The boat's awesome, it's been a real pleasure.
CigDaze is offline
Old 11-11-2005 | 09:54 AM
i know about the 2 rating, but what are they /class?
Boomer35 is offline
Old 11-11-2005 | 10:16 AM
CigDaze's Avatar
Class 1
Trailer Hitch with capacity of up to 2000# gross trailer weight and 200# tongue weight.
Class 2
Trailer hitch with capacity of up to 3500# gross weight and 350# tongue weight.
Class 3
Trailer hitch with capacity of up to 5000# gross and 500# tongue weight. Also sometimes refers to a hitch with a 2" receiver regardless of rating.
Class 4
Trailer hitch with capacity of up to 10000# gross trailer weight and 1000-1400# tongue weight. Although many times any hitch with a capacity greater than 5000# gross weight is referred to as a Class 4.
Class 5
Any Trailer hitch with capacity greater than 10000# gross trailer weight and 1000-1200# tongue weight. Usually a 2.5" receiver or in some special cases a 2" receiver.
CigDaze is offline
Old 11-11-2005 | 10:28 AM
CigDaze's Avatar
And as far as weight carrying verse weight distributing, that's a function of the vehicle and hitch combination, so there's no set value.
On My '05 F-250, for instance that came with a class 3 hitch as stock, the plate on the hitch says: "5000# Gross Trailer weight / 500# Tongue weight when weight carrying, or 12,500# / 1250# weight distributing." But it's different for each vehicle.
CigDaze is offline
Old 11-11-2005 | 12:40 PM
two-air's Avatar
So with your truck could you tow a boat trailer combo up to 12500 lbs??
two-air is offline
