Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Engine hatches, how to build >
Old 11-12-2005 | 09:28 AM
Dave M's Avatar
Veteran: Navy
Default Engine hatches, how to build
I'm looking for info on how to build an engine hatch. Materials, technices, etc. It does not have to be very elaborate. It must be strong enough to walk on though. Something like what is pictured.
Dave M is offline
Old 11-12-2005 | 12:29 PM
Default Re: Engine hatches, how to build
I'm building a set of race hatches for my Cig. A wooden box frame with 4 crossmembers all screwed together with galvinized screws. Then covered with 12 oz triaxial fiberglass with epoxy resin on the bottom and 10 oz on top. I'm not done yet but heres a few tips for you:
1. Every edge that you're putting fiberglass on has to have a radius or it will not stick right
2. You're first fiberglass job will most likely become you're first fiberglass repair job too.
Good Luck, Theres some people that a really talented with that stuff on this board, I'm hoping to pick up some tips too.
Dangerous Dave is offline
Old 11-12-2005 | 01:01 PM
Comanche3Six's Avatar
Dave
I just had one built out of Kevlar by Fiberglass Plus. I wanted to eliminate the sunpad and add scoops. If you decide to have it done by a professional, I can highly recommend this company.
Ed
Comanche3Six is offline
Old 11-12-2005 | 04:32 PM
Dave M's Avatar
Veteran: Navy
Thanks for the info guys. I think over the winter I'm going to do some experimenting on a small scale and see how it comes out.
Dave, how do you get the topside to be smooth? Did you gelcoat it after the fiberglass? What kind of wood did you use?
Dave M is offline
Old 11-13-2005 | 01:53 PM
I'm not done yet but I plan to get it smooth using an epoxy "flood coat" and then lightly sanding and then painting with awlgrip. I have to paint it because the epoxy I use will yellow a little because of UV rays. For wood I used poplar for the frame and oak 1/4 inch plywood for the deck. Keep in mind I don't really walk on my hatch, I have stood on it and jumped up and down to test for strength but if you want to walk on it I'd use 1/2 inch plywood. Also, don't buy fiberglass or resin from West Marine or any other boating store, It's a rip off. Theres plenty of places you can find online that will ship it to you if you don't already have a local source. I'll post pictures of my project soon so hopefully you can learn from my mistakes.
Old 11-13-2005 | 07:19 PM
Dave M's Avatar
Veteran: Navy
Hey Dave,
Did you glass one side wait for it to cure and then glass the other side? I'm trying to visualize how it would be done without a mold.
Dave M is offline
Old 11-13-2005 | 07:59 PM
yes, exactly. I did the bottom first so I could wrap the fiberglass around and the seam wouldnt be visible from the outside
Old 11-13-2005 | 10:33 PM
Originally Posted by Comanche3Six
Dave
Ed
Do you have any of their contact information? What was the cost?
scottie150 is offline
Old 11-14-2005 | 06:55 AM
Dave M's Avatar
Veteran: Navy
I was thinking I could make a mold to make the job much easier. I was thinking of using wood but the glass would probably want to bond to it. What can you make a mold out of or what can you put on it that would keep the glass from bonding to it?
Dave M is offline
Old 11-14-2005 | 08:34 AM
Audiofn's Avatar
Charter Member #232
MDF (Medium Density Fiber Board) works well for molds. Hard part is figureing out the reverse. The way that they ussually do it is make the part, then make the mold out of the part, then make your hatch in that. For a one off then your best bet is to just make the hatch and glass it IMO.
Jon
Put your best foot forward!
Audiofn is offline
