Redline Heavy Schockproof Outdrive Oil >
Old 11-13-2005 | 08:35 AM
Default Redline Heavy Schockproof Outdrive Oil
I am currently using this in my 1986 Alpha 1. This drive has never been apart except to change the water pump impeller.My question is when the oil is new it's a dark red color,this season when draining for winter maintenance the oil is red-gray in color but more gray than red. What should it look like?
David Stotz is offline
Old 11-13-2005 | 08:48 AM
GOODT's Avatar
Default Re: Redline Heavy Schockproof Outdrive Oil
it should be red like when you put it in, it means that you have water intruesion some where, would suggest that you have drive pessure tested. you might want to check out the below link also........
http://www.offshoreonly.com/forums/s...d.php?t=115607
GOODT is offline
Old 11-13-2005 | 11:38 AM
Hydrocruiser's Avatar
Arrow Re: Redline Heavy Schockproof Outdrive Oil
sounds like water got in
Hydrocruiser is offline
Old 11-13-2005 | 09:04 PM
When pressure testing the drive should it be filled with lube? What is the test pressure? How long do you run the test? What about a vacuum test?
Thanks for the replies so Far!
Old 11-14-2005 | 07:31 AM
GOODT's Avatar
You pressure test withthe drive empty,up to about 10 psi merc actually says 5 psi I think I like to do it at 10 for about 5 min...and yes vacum test is part of it also
GOODT is offline
CPPerformance
New Products and Member Discounts
5
11-24-2010 11:32 AM
Hydrocruiser
20
02-19-2009 10:50 AM
thunderdan
0
08-14-2003 08:28 PM
mlitefan
07-29-2003 02:41 PM
CAP071
32
04-19-2003 03:47 PM
