Go Back  Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
New Product Intro - A Wicked New Drive Shower >
Old 11-16-2005 | 12:36 PM
CPPerformance's Avatar
Default New Product Intro - A Wicked New Drive Shower
Just Wicked Marine has taken Drive Shower technology to the next level!
Just Wicked Marine has developed a drive shower that has out performed every competitor's drive shower tested to date.
The NEW Crossfire Dual Port Drive Shower
Fits Alpha One, Alpha One Gen II, Bravo One, Bravo Two, and Bravo Three Drives.
Just Wicked Marine’s newly designed Crossfire Drive Shower/Cooler kits bring drive shower technology to a new level. Thanks to the 2 specially designed adjustable mounting clamps ,this shower/cooler will fit Alpha One, Alpha One Gen Two, Bravo One, Two and Three.
Comes with allen wrenches, drill bits (one for a pilot hole and a 1/2" bit with a 3/8 shank) and full color illustrated installation instructions. No other Drive Shower Manufacture supplies you with the tools you need.
This shower/cooler has out performed every competitor's drive shower/cooler tested to date. Has specially designed and tested pick ups that forces the water up the tubes and with the 21 redesigned dump ports that sprays the water across the drive in a fan pattern the water is contacting more of the drives hot surface. Pick-up ports are adjustable up to 1-1/2 inches. With Just Wicked Marine’s Shower/Cooler design you get more water flow and lower drive oil temperature.
This Shower/Cooler has 3 times the water flow than the very popular shower cap design and has a 15-35 degree lower drive oil temp. Guaranteed or full refund.
Plus these are the only Shower/Coolers on the market today that you can get in colors. Available in your choice of Satin, Polished, Red, Blue, Purple, Teal or Black.
For lots more information and test results CLICK HERE.
List - $126.95
Our Price Starting at $109.95
ORDER ONLINE
CPPerformance is offline
Old 11-22-2005 | 05:42 AM
mwdill's Avatar
Default Re: New Product Intro - A Wicked New Drive Shower
will it work with add on steering?
mwdill is offline
Old 12-07-2005 | 06:34 PM
Sydwayz's Avatar
Forum Regulator
No way that would work with my Marine Machine Steering collars.
Sydwayz is offline
Old 12-08-2005 | 11:43 AM
If your add-on hydraulic steering system uses an End Cap such as with the Hardin Marine or IMCO systems then this type of drive shower will work.
If your steering system uses a Wing Plate like Marine Machine then this drive shower would not work due to interference with the wing plate.
Old 12-09-2005 | 09:18 PM
mwdill's Avatar
mwdill is offline
Old 12-13-2005 | 02:03 PM
SUPERSTITIOUS's Avatar
How about an XR drive with ITS and the finned cap
SUPERSTITIOUS is offline
Old 12-13-2005 | 06:15 PM
Good question. We just mounted one on an XR with the finned cap to find out. We had to add 2 threaded spacers and a couple of bolts but other than that it fits perfectly.
We'll get a supply of the spacers and bolts, create a new part number for the XR kit. I'll let you know by posting here when we have it all together, should not take but a week or so to get the extra parts in.
Old 12-17-2005 | 03:10 PM
wrinkleface's Avatar
How about Xr w/ ITS and sportmaster lower? Thanx Wrink
wrinkleface is offline
Old 01-05-2006 | 08:35 PM
any updates?
Old 01-06-2006 | 11:22 AM
The shower is now available to fit the XR drive with finned top cap. Same price, just give us a call to place your order 800-225-9871. We don't have this model up on the web site yet but we'll get it listed there ASAP.
