Lifting 2 wheel drive dually?
Old 11-24-2005 | 12:33 PM
plumbers crack's Avatar
Talking Lifting 2 wheel drive dually?
Can this be done coil springs in front.I am looking to put 19inch or 22 inch rims on.Anyone got a source for rims and tires.Most of the trucks in key west were all jacked up and looking cool.
plumbers crack is offline
Old 11-24-2005 | 01:30 PM
Default Re: Lifting 2 wheel drive dually?
how tall are you wanting to go?
FOUNTAINFAMILY is offline
Old 11-24-2005 | 05:17 PM
Question Re: Lifting 2 wheel drive dually?
Just would like to get tires and rims on without hitting fenders.19-22 inch rims Im not sure what size tires are available or the height.That will determine lift.Can it be done?
Old 11-24-2005 | 05:45 PM
offshoredrillin's Avatar
yes it can be done, you can have bolt on 19.5's and run toyo tires and be within one half inch of the original tire size...go to www.brentzwheels.com or call me and I can get them for you and have them drop shipped. complete shipped to you would be about 5500.00 with tires and with equal in them to self balance.
here is mine 19.5 lightening...lowered o1 GMC dually lowered 8 and 6
offshoredrillin is offline
Old 11-25-2005 | 03:01 PM
Talking Re: Lifting 2 wheel drive dually?
That rig is nice!Im looking to go up in height.What is required to lift the truck.The front sits down lower than the rear.I would at least like to even out the truck.Larger coil springs in front?Different springs in the rear?The rims are nice big bucks $$$
Old 11-25-2005 | 03:07 PM
Thanks, Brent forges his own rims and hubcentric drills them...they are pricey but they also are the best... fabtech usually has the kits for raising 2wd trucks. on fords the torsion bar will raise them and on some of the GM's I think you can with the torision bar as well. taller or stiffer springs may level it out. if the springs out of a 4wd model fit, that may work as well too. The 19.5' will fit perfectly and I believe the 22's will as well, just have to check on clearance in the wheel housing. See if Fabtech has anything for you....Rob
Old 11-25-2005 | 07:06 PM
went to there site,looks like I will have to call the tech line.Thanks!
tgersx
3
10-09-2007 07:39 PM
Slick02
21
12-21-2006 12:45 PM
b717200
37
05-23-2005 10:44 PM
BajaRunner
10-30-2004 06:47 PM
Sandahl
0
07-03-2003 03:29 PM
