Pushrod problems >
Pushrod problems
Pushrod problems
Old 11-27-2005 | 02:47 PM
PatriYacht's Avatar
Default Pushrod problems
I was taking my engines apart for some winter maintanence and I found half of my pushrods were cracked. These are the reccomended Crane pushrods with pressed ends that you would use with a 741 Crane cam. They have about 100 hrs. on them. Any ideas what would cause this. My spring pressures are 150 seat and about 470 lb/in. The springs do not coil bind.
PatriYacht is offline
Old 11-27-2005 | 04:44 PM
ratman's Avatar
Default Re: Pushrod problems
go with one peice hardened moly .080 wall instead
ratman is offline
Old 11-27-2005 | 04:59 PM
PatriYacht's Avatar
Ratman, do you have a prefered brand?
Old 11-27-2005 | 05:09 PM
JCPERF's Avatar
Comp cams, Jesel are a few.Stay away from Manley one piece pushrods.They are junk!!!!I have seen sticks of butter that is harder than their pushrods.
JCPERF is offline
Old 11-27-2005 | 05:29 PM
PatriYacht's Avatar
Thanks for the info!
Old 11-27-2005 | 08:26 PM
formula31's Avatar
had the same problem. All one piece top dollar ones now. Comp cams I think.
formula31 is offline
Old 11-28-2005 | 08:05 AM
Manton's, Smith Brothers are both good products.
cstraub is offline
Old 11-28-2005 | 10:53 AM
Had Comp Cams one piece 3/8 in my race motor, 290# on the seats, .785 & .810 lift, over 600 runs plus dyno time, never a failure, available in .050 incriments for any application. Was a 540 Super Gas drag motor.
Bubbletop409 is offline
Old 11-28-2005 | 11:34 AM
I stick with PRC's or Comps.
hellbents10 is offline
Old 11-28-2005 | 11:51 PM
TC's Avatar
TC
Comp Cams Hi-Tech .080 wall 4130 seamless one piece chromemoly here.
TC is offline
