yo jcperf
Old 11-27-2005 | 06:09 PM
ratman's Avatar
Default yo jcperf
here are my options on exhaust, i can get stainless marine gen III's with 5" dry tails for about 2750 a pair, or i can get two pair of low hour cmi split tops from my engine builder for around 5 k and reuse my 4.5 tails with the gaffrig mufflers. which set up do you think will make more hp on a 588ci 1000hp blower motor? thx, ratman
ratman is offline
Old 11-27-2005 | 06:19 PM
JCPERF's Avatar
Default Re: yo jcperf
The Stainless marine exhaust is less restrictive then the CMIs.The CMIs will choke a 1000HP engine by up to 40 HP up top.I would buy the Stainless exhaust over the CMI.5 inch tails are better to have.The dry is worth some power if you dont have strict noise regulations
JCPERF is offline
Old 11-27-2005 | 06:24 PM
ratman's Avatar
thx a bunch for your input, the gen III's it is! thanks again, ratman
ratman is offline
Old 11-27-2005 | 06:25 PM
JCPERF's Avatar
Put them under the rubrail HOTROD!!!
JCPERF is offline
Old 11-27-2005 | 06:31 PM
1 7/8 runners of the split tubes are not enough.
800XCR is offline
Old 11-27-2005 | 07:09 PM
Hauling Trash's Avatar
JCPERF
You owe me some money ($100) Smitty beat Joe in Super V.
Mike
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Hauling Trash is offline
Old 11-27-2005 | 07:14 PM
JCPERF's Avatar
Originally Posted by Hauling Trash
JCPERF
Mike
Did we confirm that bet?
JCPERF is offline
Old 11-27-2005 | 07:52 PM
'05 Concept SF23
Ratman, I ran SM GEN III on my Black Thunder. You have to be very careful about center distance in side by side installations. Check with Brownie @ SM on that issue. Also I was always having exhaust leaks. The rigging was tall decks on transmissions to #5 plug ins. The 5"pipes went tru transom and were dry to the very last 1/2". I think if you gave the tail pipes some type of mid distance support you might keep them sealed. With the kind of running you do you need to check this out very carefully. Joe Murray
f311fr1 is offline
Old 11-28-2005 | 08:53 AM
ratman's Avatar
jc look how high my drives are! #3's jacked way up to get the x where it need to be i dont have room to 5" tails thru transum.
ratman is offline
Old 11-28-2005 | 08:56 AM
ratman's Avatar
plus it looks mean with the tubes pokin thru the engine hatch
ratman is offline
