Tail Pipes For Cmi Sport Tube.
I Need 2 Pairs Of Tail Pipes For Cmi Sport Tubes (bravo) Set Up Any Body Have Them?? I Think It Is The
Old Style That Slip On And The Clamp Holds It On
With The Bolt On The Bottom. Thanks Pic's If You Have Them
While I am not sure these are what you want, the tails I have pictured are nearly new. I bought them new, used them 1 poker run this year and decided to go for full dry tails.
I have have some and also have 1 set of the adapter rings to convert your headers to except the new style. I got the adapters from Fred @ Trick Marine they are easily welded on. I ended up going with Lightning and someone wanted the headers w/o tails.502-262-7782 Alex
