Hydraulic Outdrive Lift / Stand >
Old 12-01-2005 | 03:40 PM
Dock Holiday's Avatar
Charter Member #34
Default Hydraulic Outdrive Lift / Stand
There was a company advertising in the classifieds a few weeks back that had a real nice hydraulic lift for outdrives that made it real easy for one person to remove and install an outdrive.
Does anyone know who this was or how I would get in touch with them to buy one.
Thank you
Dock Holiday is offline
Old 12-01-2005 | 03:58 PM
GOODT's Avatar
Default Re: Hydraulic Outdrive Lift / Stand
Yard arm makes the nicest ive seen
http://yardarm.com/
Attached Thumbnails Hydraulic Outdrive Lift / Stand-logo1111.jpg
GOODT is offline
Old 12-01-2005 | 04:01 PM
articfriends's Avatar
There is one that a local company in kawkalin,Mi is making that looks like a adapted engine stand that lifts the drive quite high for 700 or 800$ . This is the one I use(a yardarm) and it works great,but it doesn't lift the drive as high as the ones that your talking about,Smitty
Attached Thumbnails Hydraulic Outdrive Lift / Stand-dr.jpg   Hydraulic Outdrive Lift / Stand-dr1.jpg
articfriends is offline
Old 12-01-2005 | 07:43 PM
Charter Member #34
Thanks guys.
Those look very nice and I plan to look into them. The guy I saw here on OSO was in Michigan. My concern is height. The boat sits on a Myco trailer that puts it up higher then most. Although I'm sure you could modify the arms if needed for the extra height.
Dock
Old 12-02-2005 | 08:28 AM
You could allways use a cheaper one and if hight is a problem just use a palet and a pice of plywood to gain hight.For me the problem is not the removel but the install is where the takeing you time is my main goal. My .02
FloridianSon is offline
Old 12-02-2005 | 12:56 PM
Charter Member # 1083
I always lift the front of the trailer. That brings the back down to a workable height.
If it's not a thunder run.............than you're just burnen fuel!!!
BOB ONEIL is offline
Old 12-03-2005 | 05:38 PM
Charter Member #34
??? 40 foot long triple axle trailer. That ain't going to work, plus you would then have the bolt on swim plaform in the way if you could do that.
I have pulled drives many times by myself, just cannot get them back on without help.
I called Yardarm and they are very nice people. I gave them or order, if you have a business they will give you an extra 10% off which brings it under $700.00. But after we completed the order, they then told me they could not ship for 8 weeks.
Still looking for the company in Michigan if anyone has their name.
Thank you.
Old 12-03-2005 | 06:06 PM
Outdrive1's Avatar
Masher touches my
If you have access to a forklift they work very well for installing drives. Just put the blades real close together and slide them inbetween the upper and lower housing. Wrap the ends on the blades so you don't scratch your drive up. Once you get close the drive will slide back and forth on the blades and you can put the drive shaft into the bearing and push the drive the rest of the way on. It's not too complicated by yourself with a forklift.
Outdrive1 is offline
Old 04-19-2007 | 08:13 AM
25 hors la loi's Avatar
Have more picture with some spec ?? ....why i don`t find this thread before ...cause right now i look to made one for two of my friend ...and realy like your idea
Thank`s in advance
Attached Thumbnails Hydraulic Outdrive Lift / Stand-hpim2894-large-.jpg   Hydraulic Outdrive Lift / Stand-hpim2898-large-.jpg
25 hors la loi is offline
Old 04-19-2007 | 08:35 AM
t500hps's Avatar
21 and 42 footers
We bought a motor cycle jack and welded a stand to the top of it to hold a drive. Roll it right up to the back of the boat and jack it as needed.....PERFECT!!! (I think the jack was less than $100 at Northern Tool)
t500hps is offline
