Changing over to MPI in my 502 >
Old 12-03-2005 | 03:54 AM
vandeano's Avatar
Default Changing over to MPI in my 502
I have a 1992 502 Magnum and was thinking about converting it over to a MPI. Is this a big job. I got a good deal on everything needed except for the ECM and wiring harness. Is this a wise choice are should I just leave it alone.
vandeano is offline
Old 12-03-2005 | 06:41 AM
Pat McPherson's Avatar
Default Re: Changing over to MPI in my 502
No it is not a big job.
Just buy the shop manual for what ever year the MPI system you got.
The ECM and wiring harness seem to be the toughest parts to come buy though. I've got a spare intake, throttle body and... with no harness or ECM too...
Patrick
Pat McPherson is offline
Old 12-04-2005 | 04:32 AM
vandeano's Avatar
I paid $320 for it on E-bay is that a good deal + $80 to ship. I still need the ECM and wiring.
vandeano is offline
Old 12-04-2005 | 07:24 PM
I have a MPI with a procharger and could provide you with info on the EFI for the 502. I might be interested in your revolution exhaust. Bob 530 587 4700 (Tahoe) or [email protected]
baronbob is offline
Old 12-04-2005 | 07:57 PM
Mbam's Avatar
Offshoreonly Advertiser
I think I have a harness for an early 502 with a Mefi 2, i would be happy to let it go cheap.
Mbam is offline
Old 12-05-2005 | 05:39 AM
East Coast B's Avatar
I've been interested in doing the same conversion, would appreciate if you could post your experience and parts list needed to do the job.
I've got 94 carbed 454 motors and was told along with the mpi unit itself, the wire harness, fuel pump and some unknown sending/sensor fittings would be needed.
Good luck and again, appreciate if you could post your findings.
East Coast B is offline
Old 12-30-2005 | 06:58 PM
Marc,
I'm interested in the harness. Can you email me at [email protected].
IHTFP is offline
Old 12-30-2005 | 07:55 PM
Michigan Mad Man
I have some ECU's and wiring harnesses also and will program them to your engine. Tyler
TylerCrockett is offline
Old 12-30-2005 | 08:30 PM
baja36ft's Avatar
HEY TYLER WHAT CAN YOU DO FOR MY 454 MAG ECU? I NEED IT TURNED UP CAN YOU HELP ME?
baja36ft is offline
Old 01-09-2006 | 09:20 AM
I converted my Carb setup to EFI. I used the Holley MPI setup with the Laptop programable ECU. I would not say it is a easy job however. It takes a lot of tweeking on the laptop but it does work pretty well. I am still having issues with getting good O2 readings for tuning on the fly. I think I may get a stand alone wideband gauge to help tune and monitor the Air Fuel Ratio.
jeffswav is offline
