Best Head Gasket for 496HO upgrade? >
Old 12-05-2005 | 08:13 AM
Rage's Avatar
Default Best Head Gasket for 496HO upgrade?
I plan to up the stock 496HO to 525hp naturally aspirated.
What would be the best head gasket for this?
Rage is offline
Old 12-05-2005 | 10:49 PM
Rage's Avatar
Default Re: Best Head Gasket for 496HO upgrade?
Anyone?
Rage is offline
Old 12-06-2005 | 05:52 AM
Pwrbt33's Avatar
Talking Re: Best Head Gasket for 496HO upgrade?
I like to use the Cometic gaskets.
John S.
Pwrbt33 is offline
Old 12-06-2005 | 08:46 AM
Nordicflame's Avatar
Cometic...
Those are included with the Raylar kit; Isn't that what your doing?
Dave
Nordicflame is offline
Old 12-06-2005 | 09:55 AM
Rage's Avatar
Dave,
Most likely but wanted to see if there is something better in head gaskets out there.
Thanks.
Rage is offline
Old 12-06-2005 | 09:58 AM
None better and you can increase your compression ratio and inprove your qwench with the variable thickness options available.
Dave
Old 12-06-2005 | 10:02 AM
Rage's Avatar
Dave
Dave,
how do you improve you quench?
Rage is offline
Old 12-07-2005 | 11:03 AM
When using the .027 gasket vs the .040 you in turn bring the head down closer to the deck reducing the qwench area. "Most" engines will have the pistons .015-.020 down in the hole from the deck at the top of the stroke. This coupled with the standard .040 gasket will give you a .060 qwench area which is not desireable for higher compressions and lower octane fuels. The target qwench area should be in the neighborhood of .040 on a high performance motor for best combustion efficiency.
Dave
Old 12-07-2005 | 11:38 AM
Rage's Avatar
Dave
Dave,
Thanks for the insight.
Why isn't the quench made standard at .040 instead of ~.060?
Rage is offline
Ken N
0
04-07-2008 03:13 PM
ur2slo
08-17-2006 10:01 PM
rssteiny
6
04-27-2004 06:47 PM
Powerboatin
10
02-25-2003 09:27 AM
traviss
6
12-06-2002 06:35 PM
