# 6 drive question for apache guys >
Old 12-05-2005 | 10:19 AM
Default # 6 drive question for apache guys
had 1.5's what is the draw back of going to 1.35's
{triple 1200's}
SLINGSHOT is offline
Old 12-05-2005 | 01:27 PM
Default Re: # 6 drive question for apache guys
ttt
Old 12-05-2005 | 02:15 PM
{triple 1200's}
Not much really, about 3 less inches of pitch on the prop you should get about the same speed. In theory, the 1.5 would be faster if you can get props with enough pitch. Reason being the props will turn slower with the 1.5s and the drag of the blades entering the water will be reduced. Thats the theory, but every boat is different. I'm not a hydrodynamic engineer, but I stayed at a Holiday Inn Express last night
ApacheCarl is offline
Old 12-05-2005 | 03:14 PM
Changing the ratio is only necessary if the prop you NEED is not available.
The heavier the boat, the 1.50:1s give better punch.
Edward R. Cozzi is offline
Old 12-05-2005 | 05:33 PM
Nykamp's Avatar
Call APACHE they were doing some gear swap set-ups on Kemo a year or so ago. Mark should be able to help you, get her do for our run next summer in ohio.
Nykamp is offline
Old 12-05-2005 | 10:10 PM
Nauti Kitty's Avatar
I went from 1.5 to 1.61 this summer, got better midrange and picked up 2 mph's. The bigger the diameter the better it stays hooked up in the rough water. What I hear anyway. Worked for me. NK
Nauti Kitty is offline
Old 12-05-2005 | 10:36 PM
Papache's Avatar
Registered User
I have 1.36's with 1550 hp I trun 17x33 4 blade props at 5800rpm 117 mph
Papache is offline
Old 12-05-2005 | 11:23 PM
Coolerman's Avatar
PF Marine
Originally Posted by Papache
I have 1.63's with 1550 hp I trun 17x33 4 blade props at 5800rpm 117 mph
With 1.63 gear sets and 33pitch props at 5800 rpm 1% slip is 110mph. They must have a lot of cup in them. 6800 rpm with 10% slip is 117mph which is still very good.
http://www.boatpropellers.com/propcalc.html
Coolerman is offline
Old 12-06-2005 | 08:46 AM
thanks
Old 12-06-2005 | 08:47 AM
cougarman's Avatar
Sling,
How close are you to hitting the water with that Bad Boy?
Cougarman
cougarman is offline
