Staggered vs sbs
Old 12-06-2005 | 12:41 PM
Default Staggered vs sbs
I am wondering how much staggering the engines gives you in top speed versus sbs installation.
I am looking at a 38 with Ilmors and Arnesons.
any ideas?
heiko
frogger1403 is offline
Old 12-06-2005 | 12:52 PM
Default Re: Staggered vs sbs
Mark McManus once told me that staggered engines made the boat faster in rough water. The outdrives running deeper meant the props stayed in the water longer and went back in sooner. Always made good sense to me, so I never questioned it.
Edward R. Cozzi is offline
Old 12-06-2005 | 01:18 PM
handleing at airborn more stablity
j mike
thedonz is offline
Old 12-06-2005 | 01:56 PM
BBB725's Avatar
Lowers and moves forward the center of gravity and puts the drives deeper in the water and is faster.
BBB725 is offline
Old 12-06-2005 | 02:36 PM
cuda's Avatar
I always thought raising the drives makes them faster.
cuda is offline
Old 12-06-2005 | 03:19 PM
The drives are lower, going down the V, relative to the center of gravity. This allows a higher X dimension, relative to the bottom of the boat. So you can run 1-2" higher X diimension, still have good trim control, go faster, and have a bigger sun deck for your "crew". What's not to like?
Gary Anderson is offline
Old 12-06-2005 | 04:23 PM
Downtown42's Avatar
and they look cool staggered what else matters
Downtown42 is offline
Old 12-06-2005 | 04:33 PM
cuda's Avatar
I'm not doubting you, but I still don't understand. If you can run the same X without lowering the engine, why would it be faster?
cuda is offline
Old 12-06-2005 | 04:37 PM
RLW
Performance aside, I like it from a maintenance standpoint.
Of course, if I had that much whip, someone else would be wrenching.
RLW is offline
Old 12-06-2005 | 04:48 PM
better balance, more speed. room to work, looks cool.
customryder is offline
