Rub Rail
Old 12-08-2005 | 03:45 PM
Default Rub Rail
Has anyone replaced the rub rail on there boat themselves, how tough of a job is it? Was the new rubrail identical with the screw holes located in the same place, and was it the same shape and mold as the old one? where is the best place to order new rubrail?
Boomer35 is offline
Old 12-08-2005 | 03:57 PM
velocitypwrbtr's Avatar
Talking Re: Rub Rail
WWW.WESTMARINE.COM
http://www.tacomarine.com/support/or..._rail_repl.htm
velocitypwrbtr is offline
Old 12-08-2005 | 04:08 PM
LIOPA's Avatar
Default Re: Rub Rail
TACO or L&L....L&L buys all of TACO's older designs. It is a two man job. Use new holes for better fit and fill new and old holes with marine silicone sealer. Also buy new screws for the job. Its a pain when the old tired screw snap and you'll need to drill them out especilly if half the installation has been done. Install new rail every other hole first and NOT TOO TIGHT....you will distort the new rail with waves in it.
Good luck.....its not hard but does take practice to master.
LIOPA is offline
Old 12-08-2005 | 04:16 PM
Audiofn's Avatar
Charter Member #232
It is easy but takes a bit of time. There are definatly tricks.
Jon
Put your best foot forward!
Audiofn is offline
Old 12-08-2005 | 04:31 PM
Playn's Avatar
You can also try rubrails.com
The holes won't line up with your existing ones so as stated earlier, fill the old holes with 3M 5200
Playn is offline
Old 12-08-2005 | 04:51 PM
Semper Fi's Avatar
It is kind of tricky....I would pay someone to do it if you haven't done it before or don't have a friend to help you that has done it before.
Semper Fi is offline
Old 12-08-2005 | 07:02 PM
do it on a warm sunny day.
have a freind help you stretch it as you go and use a heat gun for the corners.
boatnt is online now
Old 12-08-2005 | 07:44 PM
cuda's Avatar
It's not too tough, if you have a helper.
Attached Thumbnails Rub Rail-10-26-003-small-.jpg   Rub Rail-10-26-007-small-.jpg
cuda is offline
Old 12-08-2005 | 07:54 PM
CAP071's Avatar
1- Friend
1 - Heat Gun
1 - Afternoon- evening
2 - Cases of BEER!
CAP071 is offline
Old 12-08-2005 | 08:13 PM
Boomer, Call me. Ive done it a few times before. There are definitly some tricks to make the job go easier
otis311 is offline
