Fuel mileage for F350 6.0
Old 12-08-2005 | 10:28 PM
racinfever's Avatar
Default Fuel mileage for F350 6.0
I recently purchased a new '05 Ford F350 6.0 SRW. I have approx. 4k miles on it and I have added the Edge Juice with attitude. My fuel mileage is still only about 13 miles to a gallon average. Truck has stock wheels with 373 gear ratio.
Any help on how I can improve mileage would be appreciated!
racinfever is offline
Old 12-08-2005 | 10:41 PM
Default Re: Fuel mileage for F350 6.0
I have an '03 dually 4:10 rear getting 14 average with a Bullydog 115 hp box.
Pure Energy is offline
Old 12-09-2005 | 06:16 AM
Jassman's Avatar
Keep the Edge on level 1 or 2 with the fuel set on 3. No jack rabit starts, no punching it on an on ramp, basically drive it like your grandma would do, not like you stole it and you will see high 15's-16's city and highway combined. The problem is when you have all that power you are always testing the performance of that module, and it takes alot of will power not to push that peddle down that extra 1/4. Also once the truck breaks in around 10k milage will get better. Jeff
Jassman is offline
Old 12-09-2005 | 06:26 AM
cuda's Avatar
My 05 stock PSD gets 18.5 on the highway at 70, and around 16 in town. 3:73 gear, 4x4.
cuda is offline
Old 12-09-2005 | 10:08 AM
racinfever's Avatar
jassman what do you mean by { fuel set on 3 } i am aware of level settings only.
Old 12-09-2005 | 12:34 PM
CigDaze's Avatar
I can get about 18mpg on the highway, cruising at 72.
'05 F-250, CrewCab, 4X4, 6.0L, 3.73 rear
CigDaze is offline
Old 12-09-2005 | 01:17 PM
Tim G.'s Avatar
Performance Boat Center
Man, my Dodge gets 36-40..
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 12-09-2005 | 06:27 PM
Jassman's Avatar
We call it smoke, there is a settng once you go through the program, power levels, then low boost fueling, set this at 3, if you want the most power the higher the level means more power. The problem s the tranny on the Ford has a learning curve, if you put it on 5 power and fueling, that will give you an approx 115hp and 250torque. Here is something I got off the dieselstop.com and thedieselgarage.com Print this info , great reading... Hope this helps Jeff
http://www.thedieselgarage.com/proje...toutreport.pdf
Jassman is offline
vette131
Spectre
8
08-22-2008 09:18 AM
FunHome
31
03-11-2008 03:01 PM
boatman22
22
12-31-2005 03:13 AM
tomtbone1993
9
03-25-2005 01:32 AM
buck183
12-09-2002 09:10 PM
