Hair line cracks in 35 lightning windshield >
Old 12-09-2005 | 11:24 AM
Default Hair line cracks in 35 lightning windshield
My 2001 35 lightning has developed hairline cracks in the windshield. (passengers side) .Anyone have experience with this problem
furnitureman is offline
Old 12-09-2005 | 11:27 AM
BLee's Avatar
Charter Mod
Default Re: Hair line cracks in 35 lightning windshield
I'm sure PLENTY of people will chime in.
BLee is offline
CBR's Avatar
CBR
www.hyperfishing.com
No way, fountains don't have any problems! Just kidding, Common problem with all boats sadly. Might want to overlay the crack with some clear adhesive on both sides. Moisture getting in it and expanding with the sun will make it worse.
CBR is offline
Old 12-09-2005 | 11:30 AM
PatriYacht's Avatar
Is it Plexiglas? Uv rays will cause Plexiglas to develop thousands of little hairline cracks. Looks like it's fogged from a distance.
PatriYacht is offline
Old 12-09-2005 | 05:24 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
That is typical of the Fountain windshields, crazing, especially the side panels.
Use of Windex or cleaners with amonia is 1 cause for it. Use only mild soap. Some think the heat build up while under the cover is another. Only way to rid them, is replace them. Then your good for a couple more yrs before it may start again. I replaced my side panels 2 yrs ago, so far still OK.
US1 Fountain is offline
Old 12-09-2005 | 05:36 PM
bouyhunter's Avatar
Does Fountain put any type of anti-reflective coating on the panels??
It's a coating that is used to cut down on the glare - also commonly used on automotive parts. It consitst of "elements" evaporated onto the panel in a high vacuum. (I work in the industry - I know a little about it).
Nothing against Fountain, but it's a pretty expensive process, and if not done properly it would explain the "crazing". It's kinf of tricky to get these things "right".
US1 - did you replace with factory parts, or just replace the Plexi yourself??
bouyhunter is offline
Old 12-09-2005 | 05:45 PM
Ginger or Mary Ann?
Went the factory route this time as was unsure how the black tint was done along the bottom. Turns out the black on mine was just paint on the inside surface. Kept my old panels to use a patterns in case I need to replace them again, at which point I'll buy a full sheet and make them myself. I 'think' Fountain wanted a tad over $200/side. I forget exactly. They are acrylic.
No coating from Fountain. They still have the paper on them from the plastic factory. Just cut to size and edges buffed smooth.
Old 12-09-2005 | 06:41 PM
itilldo's Avatar
Instead of Plexi how about using Lexan (sp?) instead? Same stuff they use for stock car winshields?
itilldo is offline
Old 12-09-2005 | 08:44 PM
Downtown42's Avatar
try this guy...
Windshields: 800-554-7527 Brad Shields Formtec Plastics
Downtown42 is offline
Old 12-10-2005 | 05:45 AM
bouyhunter's Avatar
This thread has got me thinking...
Ever thought of a mirror coat to match your boat - kinda like sunglasses??
Any interest?
