What to make custom Oil pan out of? >
Old 12-11-2005 | 09:56 PM
2112's Avatar
Default What to make custom Oil pan out of?
Having custom Oil Pans made. Last set was made of Stainless, Outrageously exspensive.
Considering Aluminum but was told they crack easy. Never had one. Also have used Canton and Dooley steel pans in freshwater boats.
Your experiences/opinions?
2112 is offline
Old 12-12-2005 | 05:41 AM
ratman's Avatar
Default Re: What to make custom Oil pan out of?
how about titanium?
ratman is offline
Old 12-12-2005 | 08:10 AM
Stainless or steel. If capacity is going to be over 8 qts go with a fairly heavy gauge steel.
cstraub is offline
Old 12-12-2005 | 08:29 AM
jdnca1's Avatar
Do not use aluminum pan it will crack!
jdnca1 is offline
Old 12-13-2005 | 08:18 PM
Hydrocruiser's Avatar
Arrow Re: What to make custom Oil pan out of?
Chrome plated steel is decent. I have seen some Moroso make and they look like a good bill of goods.
Hydrocruiser is offline
Old 12-14-2005 | 12:16 AM
2112's Avatar
what to coat with besides chrome? Powdercoat?
2112 is offline
Old 12-14-2005 | 05:22 AM
Iggy's Avatar
If not painting, even if it is painted, the steel should be coated/plated to prevent corrosion. A plating process would be better because the chemicals will penetrate into surface cracks, seams, etc and seal the surface. Painting or powder coating can miss and cover these areas allowing corrosion to form beneth.
I used know which Mil. Spec. process would be correct for use on steel. Any plating shop can tell you.
CAD plating comes to mind. That's the yellow/gold color on bolts, oil pans, etc.
Iggy is offline
Old 12-14-2005 | 06:02 AM
resurrected's Avatar
If you can find it, unobtainium.
resurrected is offline
Old 12-14-2005 | 06:44 AM
Look on the Stef's Performance site. Quality oil pans.
ROTAX454 is offline
Old 12-14-2005 | 09:45 PM
mopower's Avatar
Toxic FORMULA
I've used numerous 10 quart steel Canton pans that are plated with a gold color material. I've left them naked and they would tarnish and oxidize some. I've painted over my latest and after three seasons and they still look good.
mopower is offline
