Catalytic Coverters by 2008...Bummer >
Old 12-14-2005 | 11:52 PM
Thumbs down Catalytic Converters by 2008...Bummer
Was reading about the EPA and CARB pushing the 5-gm HC=NCx Standard to be in place by 2008.
This means Catalytic Converters for marine inboard and stern-drive engines...but at the next meeting considerations are being made to exempt engines over 500hp. I'm sure the CARB Board of directors will include all marine engines regaurdless the amount of power.
Better buy that big power boat before 08.
Back4More is offline
Old 12-14-2005 | 11:56 PM
Semper Fi's Avatar
Default Re: Catalytic Coverters by 2008...Bummer
Semper Fi is offline
Old 12-15-2005 | 12:00 AM
Sean H's Avatar
A to Z
This means Catalytic Coveters for marine inboard and stern-drive engines...but at the next meeting considerations are being made to exempt engines over 500hp. I'm sure the CARB Board of directors will include all marine engines regaurdless the amount of power.
wait till they figure out how to put a fuel rating on boats....
Sean H is offline
Old 12-15-2005 | 12:03 AM
aquaforce's Avatar
Entirely to much enviornmentalist agenda
aquaforce is offline
Old 12-15-2005 | 12:05 AM
Gasoline powered lawn equipment is next....
Old 12-15-2005 | 12:24 AM
aquaforce's Avatar
A red hot cat conv in a glass boat with carpet and ropes...a recipe for a fiery disaster
Old 12-15-2005 | 04:54 AM
Iggy's Avatar
You bet.
Doesn't the Coast Guard Regs say that the exhaust system can't go over 200* in temp? A catalytic converter can't be water cooled because it needs the high heat to light off.
Iggy is offline
Old 12-15-2005 | 06:59 AM
They may try to get the emissions down, but it won't be a catalytic converter as we know it now. Like Iggy said: It needs the heat for the chemical to "convert" the emissions. Totally not practical in a closed bilge.
Edward R. Cozzi is offline
Old 12-15-2005 | 07:15 AM
dockrocker's Avatar
Since when did "practical" carry any weight with CARB? These are the same geniuses that mandated the automakers sell X% of electric cars in California, even though there was zero demand.
Yet another reason I am SO glad we didn't relocate out to the land of fruits and nuts; 6 months in that place and I'd be shooting someone....
dockrocker is offline
Old 12-15-2005 | 07:46 AM
Airpacker's Avatar
A typical oxidizing catalytic convertor needs to reach 600 degrees F to start functioning. Its basically a chemical furnace. The fact that most marine engines run at 12 to 1 a/f ratio will also be a huge problem to overcome with a cat. Cats like 14.7 to 15.2 to 1 to function properly. At 12 to 1, the life expectancy of the cat would be somewhere between short and none.
Airpacker is offline
