HD Engine Coupler for 89' B1? >
Old 12-15-2005 | 11:04 PM
mtgbiker's Avatar
Default HD Engine Coupler for 89' B1?
Does anyone have a merc p/n for this application?
mtgbiker is offline
Old 12-16-2005 | 05:43 AM
Default Re: HD Engine Coupler for 89' B1?
check on this part # 18311 a 17 coupling which is suitable for 502 mag mpi bravo 1 engines ....hope this helps ....cheers al.
ajl marine is offline
Old 12-16-2005 | 11:00 AM
mtgbiker's Avatar
It looks like this is the new number to merc's p/n 861523 A9 coupler. So is this Steel or aluminum?
mtgbiker is offline
Old 12-16-2005 | 11:52 AM
racinfever's Avatar
engine coupler with steel hub #861523a11 a9 is alum.
racinfever is offline
Old 12-16-2005 | 12:15 PM
sterndrivespec's Avatar
i have them in stock for a very good price if you need one,chris
sterndrivespec is offline
Old 12-28-2005 | 10:21 PM
Chris,
I need 2 H/P couplers for some 540's currently being built is this the Number?
Thank You Emmett
NotBoyToyz is offline
Old 12-29-2005 | 12:29 PM
Big Block Billy's Avatar
How Much torque and horsepower can one of these take ? Also beware of used ones on ebay with badly worn splines. If buying a used one have them clean splines and take good picture. Splines should be square looking at their top instead of triangle and pointy. If in doubt, walk away...BBB
Big Block Billy is offline
Old 12-29-2005 | 04:06 PM
racinfever's Avatar
Originally Posted by NotBoyToyz
Chris,
Thank You Emmett
New in the box 450.00 each with steel hub 513 561-4849
Old 12-29-2005 | 04:42 PM
Question Re: HD Engine Coupler for 89' B1?
Does anybody re-hub these ? I've been throwing too many away, maybe there is a cost effective fix > BBB
Old 12-29-2005 | 04:47 PM
racinfever's Avatar
A11 coupler with steel hub will handle lots of HP for a long while !
