whats the difference on 310 and 330 h.p 7.4 mpi >
Old 12-31-2005 | 03:22 AM
snake plissken's Avatar
Default whats the difference on 310 and 330 h.p 7.4 mpi
can some one tell me whats the difference on the two engines ? mine is a 1999 7.4 310 MPI noticed there are 330 HP MPI engines as well both look identical from what i can tell thanks vince
snake plissken is offline
Old 12-31-2005 | 08:20 AM
Payton's Avatar
Charter Member #927
Default Re: whats the difference on 310 and 330 h.p 7.4 mpi
I think they are the same engine. The 330 hp is rated at the crank and the 310 is rated at the propshaft.
Payton is offline
Old 12-31-2005 | 09:02 AM
Big Block Billy's Avatar
Thumbs up Re: whats the difference on 310 and 330 h.p 7.4 mpi
Correct, basically same motor inside..., I like the mark 4's better !
Big Block Billy is offline
Old 12-31-2005 | 09:46 AM
JS232's Avatar
You guys are confusing with the old carb version, I think He's talking about the two MPI versions...
7.4 MPI had 310 HP at the prop
The 7.4 MPI LX had 330 HP at the prop... I heard the ECU was different... I don't think there was mutch differences in the internals... Maybe the heads?
JS232 is offline
Old 12-31-2005 | 11:51 AM
Talking Re: whats the difference on 310 and 330 h.p 7.4 mpi
Either way not enough power for me BBB
Old 12-31-2005 | 01:44 PM
The 7.4 EFI Horizons had even more HP and were fresh-water cooled!
Edward R. Cozzi is offline
Old 12-31-2005 | 02:42 PM
JS232's Avatar
I think you are confusing with the INBOARD version witch is probably 10-20 more HP at the prop considering there is no drive but a shaft. The sterndrive versions of the Horizon had the same HP's than the standard blocs.
JS232 is offline
Old 12-31-2005 | 03:54 PM
JCPERF's Avatar
20 Hp
JCPERF is offline
Old 12-31-2005 | 04:22 PM
FOUNTAINATLAST's Avatar
Originally Posted by JCPERF
20 Hp
We knew you were smart.....
FOUNTAINATLAST is offline
Old 01-01-2006 | 11:06 AM
JS232's Avatar
Sure, He's a SBRT Einstein....
JS232 is offline
