some head flow #'s I found >
Old 01-05-2006 | 02:01 PM
Rookie's Avatar
Default some head flow #'s I found
On the bottom of the page it has a few links of different out of the box and oem flow #'s with and without exhaust pipe. In case some people were curious. I don't know how bias this mag might be.
http://chevyhiperformance.com/techarticles/41598/
Rookie is offline
Old 01-05-2006 | 03:47 PM
PatriYacht's Avatar
Default Re: some head flow #'s I found
That's good info Rookie, and I think it's accurate based on what I've seen other places. It's kind of old info though. They need to catch up with the newer heads like the AFR's and Pro-Filers. Just as a reference my AFR335cnc heads with a little exhaust work by Jim V. flowed on the same bench at the same vacuum 380 intake @ .600 and 290 exhaust @ .600.
PatriYacht is offline
Old 01-05-2006 | 04:01 PM
Rookie's Avatar
I was just looking to find numbers on maybe old and used stuff, stuff us on a budget that we might find in some elses garage. I would not want to pick up some of those peanut heads on accident.
Rookie is offline
Old 01-06-2006 | 12:12 PM
i have flow # on the edebrocks heads from my bulder if some can post for me i will email it to you.
amer3 is offline
Old 01-06-2006 | 04:05 PM
Rookie's Avatar
[email protected]
Rookie is offline
Old 01-06-2006 | 04:35 PM
Commander112's Avatar
Check out AFR 335 CNC head. A buddy put a pair on some 572's and those motors scream!
http://www.airflowresearch.com/
Commander112 is offline
Old 01-07-2006 | 11:35 AM
Strip Poker 388's Avatar
Rob
Thanks for the link
http://chevyhiperformance.com/techar...8/index9.html#
Strip Poker 388 is offline
Old 01-07-2006 | 12:41 PM
Nykamp's Avatar
Jimmy V is The man for heads, he can now be reached at Innovation in florida.
Nykamp is offline
Old 01-07-2006 | 01:23 PM
Outdrive1's Avatar
Masher touches my
I just bought a set of those Canfields, looks like I made a good choice.
Outdrive1 is offline
Old 01-07-2006 | 03:04 PM
Rookie's Avatar
Amer3's, edelbrock 61559 flow #'s
Rookie is offline
