'03 Chevy Pickup with spongy brakes >
Old 01-05-2006 | 02:18 PM
Default '03 Chevy Pickup with spongy brakes
Picked up this truck with 28,000 miles. Brakes engage normally, but the pedal is just about at the floor when the truck comes to a stop. Lots of bleeding didn't improve it. Didn't see anything obvious like warped pads. Are they all like this? It's hard to describe, but after driving hundreds of thousands of miles in a ton of different vehicles, you know when something's odd. Any suggestions would be appreciated. Meanwhile, I'm trying to find a cpmparable vehichle to see if they're all like this.
Lmarth is offline
Old 01-05-2006 | 04:05 PM
Registered User
Default Re: '03 Chevy Pickup with spongy brakes
Drums or discs on the rear?
My Tahoes w/ drums on the rears were all like that... scary to tow with.
Have you purged and replaced brake fluid? If you get contaminated or wet fluid you'll have sponginess. Use a silicone fluid to replace
Chris Sunkin is offline
Old 01-05-2006 | 04:30 PM
Ted G's Avatar
There is a recall for that, check with a dealer. My 92 did the same thing till I put on new rear shoes and it fixed it, don't know why???
www.cbpba.com
Ted G is offline
Old 01-05-2006 | 05:25 PM
Four wheel discs...
Lmarth is offline
Old 01-05-2006 | 06:43 PM
GOODT's Avatar
did you vacum bleed or the old fashioned way(pump pedal) alot of the new abs brake systems wont bleed right except by vacum can check tomorrow for you on alldata at the shop can also check for recalls if you email vin
GOODT is offline
Old 01-05-2006 | 07:14 PM
Joe-Good to hear from you again. Brakes were bled using both techniques. I'll email or PM you the VIN tomorrow (I've got the flu bug). I appreciate all the help from you and all the other folks. Is the ABS system a possible contributor to these kinds of problems? Lou
Lmarth is offline
Old 01-05-2006 | 10:45 PM
GOODT's Avatar
yes
GOODT is offline
Old 01-06-2006 | 06:25 AM
The reason I ask is that I had an ABS "mis-fire" problem on our Expedition where the ABS would engage on every stop. The brake pedal would pulse and just before coming to a stop, the pedal would drop almost to the floor. The vehichle wasn't safe to drive that way so I pulled the ABS fuse and got a normal pedal.
Lmarth is offline
Old 01-06-2006 | 07:24 AM
offshoredrillin's Avatar
I had the same problem with my 95, put in a new master cylinder and all better. Was like 95 bucks, bench bleed it and your done in half an hour...
offshoredrillin is offline
Old 01-06-2006 | 07:33 AM
Registered User
The master cylinder is sometimes the culprit but pretty unlikely with a vehicle this new.
