what is the ideal water temp for a hi po n/a engine? >
Old 01-06-2006 | 07:55 AM
ratman's Avatar
Default what is the ideal water temp for a hi po n/a engine?
was wondering what water temps you guys with larger hi po n/a engines are running for water temp, thx ratman
ratman is offline
Old 01-06-2006 | 12:23 PM
kaama82's Avatar
Default Re: what is the ideal water temp for a hi po n/a engine?
mine 120 degrees, no condensation on breathers
kaama82 is offline
GOODT's Avatar
I like to keep them at least 140 but no more the 170 on sea water cooled motor the closer to 170 the better
GOODT is offline
Old 01-06-2006 | 12:36 PM
Wobble's Avatar
SORE MEMBER
Mine runs 165-170* with 240* avg oil temp.
Crossover with bypass setup
Wobble is offline
Old 01-06-2006 | 01:23 PM
PatriYacht's Avatar
Where do you get a 120 thermostat?
PatriYacht is offline
Old 01-06-2006 | 01:38 PM
Wobble's Avatar
SORE MEMBER
I'm guessing it looks like a 1.5" hole
Wobble is offline
Old 01-06-2006 | 01:43 PM
I've always run the coolest that allows the oil to get up to temp.
Gary Anderson is offline
Old 01-06-2006 | 01:45 PM
racinfever's Avatar
ARIZONA SPEED & MARINE
racinfever is offline
Old 01-06-2006 | 11:48 PM
SeaRay Jim's Avatar
Deja vu.....
160 tstat. 170 and max of close to 175 on hard runs. 540 carb.
SeaRay Jim is offline
Old 01-07-2006 | 10:32 AM
I run our N/A engines that are 9.5:1 - 10.0 compression @ 140 degree. I would recommend running Hardin Marine oil Thermostats as well with a the proper size oil cooler. Running the water temp past 160 you will lose actually lose horsepower.
Dean Gellner
Gellner Engineering Marine Power
mrhorsepower1 is offline
