What was i thinking!!
Old 01-06-2006 | 08:31 AM
JLAY's Avatar
Yesterday evening i went home from work early to start installing a wooden floor in the cabin of my boat. My dad had some left over from his house. Anyway i dont know what the hell i was thinking because when i was drilling the piliot holes i drilled through the bottom of the boat. Now i have two freaking holes in the bottom of my 26 infinity. I was so pissed i wanted to beat my dog. Well my question is what do i fix this with. Do i use some bubbles, or does 3M make a marine filler? Thanks in advance for any info. Jlay
JLAY is offline
Old 01-06-2006 | 09:14 AM
Formula Outlaw's Avatar
Default Re: What was i thinking!!
Might try gluing a hardwood dowel in it's place, leaving about a one eighth inch deep "divit" and use Marine Tex to fill that in.
Otherwise ask a legit glass guy what to do.
Formula Outlaw is offline
Old 01-06-2006 | 09:32 AM
Wobble's Avatar
SORE MEMBER
I ran a screw through the bottom of my boat.
Roughed out the hole from the bottom with a course dremel bit and filled with marine-tex, sanded it down carefully. You cant tell. For the hole inside. plug with dowel as Formula suggests or mix up some fiberglass resin and inject with one of those syringes that you use to inject meat with marinade.
Wobble is offline
Old 01-06-2006 | 09:33 AM
Roger 1's Avatar
I would suggest a pad lock on your tool box.
Roger 1 is offline
Old 01-06-2006 | 09:37 AM
ratman's Avatar
lmfao
ratman is offline
Old 01-06-2006 | 09:49 AM
t500hps's Avatar
21 and 42 footers
That's funny chit right there!!!!
t500hps is offline
Old 01-06-2006 | 10:12 AM
Ah...who among us hasn't done something even worse...
I saw a guy cut a hole in his dash for a GPS and put a matching hole in his cabin door that happened to be open at the time!
No, it wasn't me, but if I was paying attention at the time I might have noticed what he was doing.
Edward R. Cozzi is offline
Old 01-06-2006 | 10:15 AM
RHC's Avatar
RHC
I think ya might need a bigger bilge pump!!
RHC
RHC is offline
Old 01-06-2006 | 10:16 AM
BK
I was at a boat race in Havasu one time, and when one team tried to launch the boat it wouldn't come off the trailer ---
Someone had accidentally screwed through the bottom of the boat to the bunks! True story.
It's one thing to mess up at home, but to mess up in front of an audience of thousands - that's priceless.
BK is offline
Old 01-06-2006 | 10:17 AM
Wobble's Avatar
SORE MEMBER
Aww come on, fess up
Time to start a thread on boat maintenance screw ups
I have a few
Wobble is offline
