Programmable knock control systems
GPM,I've never heard of J&S before.However,their web site is very interesting.If the the system works as stated, you have made a big contribution to the marine engine by identifying the product.Do you have any further opinion or knowledge of this product or similar products?
I found MSD and Livorsi make knock monitors, J&S is the only one I found that actually does something to control detination. I've talked to the owner of the company several times now, he's been in business since the early 90s. I'm planning on buying one next week. If it works, and I'll know first hand, it sure would make tuning easier. I would think the head gaskets, pistons, the motor would last longer, if detination could be controled. J&S states the knock sensor can be adjusted to work with my solid roller cam, I set the amount of timing retard I want to run. The dash mounted monitor tells when the motor starts to detinate, and how much timing is being removed.
WE have two new engines in the dyno room now.They make 1,000 HP on 92 octane,non inter cooled.The supercharger is under driven 18% , F/A ratio is 12:1 at 6,000 , boost is 6.2 and timing is phased @31 degrees.However,we would like to start adding timing some where around 3,000 rpm.Whereas,the system is closed loop,it may be capable of adding that advance curve along with the other features.Yesterday,we looked at the crane HI-6.However,it doesn't offer some the features J&S claims,especially closed loop and individual cylinder control.My biggest concern is electronics cross talk and EMI and RFI----------------any comments will be appreciated!!!!
I was told the individual cylinder control works with the analog MSD ignition box, but may be a problem with digital. All 8 cylinders may need to be controled together. It would be nice to hear from someone that has experiance with the unit.
CcanDo, my boat will be in storeage for a while yet, so I have no way to test the knock system, I'm very curious how well it works. If you end up trying it could you post the results?
GPM: Tom Earhart was using these before he went to an EFI with knock control.
CcanDo: The unit was mentioned here: http://www.offshoreonly.com/forums/s...xes#post494334
cobra marty: I'm happy to hear you liked the unit. We sold a couple hundred of those to Kenne-Bell, for his Syclone/Typhoon customers.
