Repairing/Replacing skegs on Bravos??? >
Old 01-09-2006 | 07:24 PM
t500hps's Avatar
21 and 42 footers
Default Repairing/Replacing skegs on Bravos???
Any thoughts on this.
My skegs were chewed up by the previous owner and the next item on the list is to get them fixed. My mechanic who has been very good to me recommends against replacing the entire skeg due to strength issues. However, I'm not sure these can be repaired to new condition.
Another shop swears 20 years of replacing 1,000's of skegs with no failures. A complete replacement would look much better but I can't risk failure at speed.
PS. Boat is a 31 Formula with stock 502's....
t500hps is offline
Old 01-09-2006 | 07:33 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Repairing/Replacing skegs on Bravos???
Replace the minimum amount for the strongest repair. I bought 2 skegs from BAM and cut out the sections I needed to restore mine back to original shape. Mine had the normal do it yourself file the edge smooth when I bought the boat. 2 yrs later and still perfect.
You can see the leading edge that I replaced on one, and the lower 1/2 on the second, only because I tried to take a little bend out of the 2nd only to have the corner break off. I thought it was best to replace with 1 section vs 2 sections. You don't have to gut and strip as I did, I just go all out whenever I do stuff. I can not find the repair now even though I did it.
US1 Fountain is offline
Old 01-09-2006 | 07:58 PM
inbetween's Avatar
I'd rather be boating!
I had mine filled and reshaped by a local welder familiar with the job. About an inch of the rear edge of one was missing (when we got the boat), and some misc. nicks and chips on both drives. Cost $100 per drive. He did a great job.
inbetween is offline
Old 01-10-2006 | 03:14 AM
AKA NoMoBoatin
Mine got broke in shipping but need it repaired on the very back of the skeg about 1.5"triangle piece.Might just put nose cones on it too.Russ just take it in and get it fixed and next time your up my way call me but i'm not holding your phone .
docmanrich37 is offline
Old 01-10-2006 | 06:53 AM
GOODT's Avatar
I agree wit US1 I have repaired many skegs with out aproblem if you get it done just use someone who does them reguarly I use millers island propeller up here for replacement if they just need cleaned up I do it my self either way ussually you cant tell anything was done
GOODT is offline
Old 01-10-2006 | 07:33 AM
t500hps's Avatar
21 and 42 footers
The leading edge of the skegs look like a serated edge of a knife and have around 3/4 of an inch of material missing along the bottom edge. The sides of the skegs are pitted quite a bit and would require alot of "filler". The strange thing is that the rest of the drives look perfect.
GoodT, are you saying you have had skegs replaced without problems?
Docman....I don't have your number. It's 1-900-NEE-DOIL isn't it?
t500hps is offline
Old 01-10-2006 | 09:36 AM
Mike Paula's Avatar
Well My biggest Bonehead move with this boat was pulling out of my driveway with the drive down . Snapped mine clean off. Took the broken piece and the drive to a local Fabrication guy I know. His work is top notch. Re repaired the skeg to a point that no filler was need to make it look factory. It has been on there two years working on a third.
Mike Paula is offline
Old 01-10-2006 | 01:51 PM
Sydwayz's Avatar
Forum Regulator
Russ,
Ping James. He had to have some work done on his, and he is all good at approaching 90mph speeds.
Sydwayz is offline
Old 01-10-2006 | 02:02 PM
t500hps's Avatar
21 and 42 footers
Originally Posted by Sydwayz
Russ,
James hasn't hit 90 yet!!! (89.XX though)
Thanks, I already talked to him and we use the same mechanic.
t500hps is offline
Old 01-10-2006 | 02:07 PM
Big Block Billy's Avatar
No Problem. If you can't find a really good shop. Send em to me and I'll get em done. I deal with an awesome shop that's welded over a dozen just for me. They charge me $75 for a skeg that's broken off clean ! BBB
Big Block Billy is offline
