Ouch! How common is this failure >
Old 01-10-2006 | 05:32 PM
Viper31's Avatar
Default Ouch! How common is this failure
Check out the gimbal picture and the description.
Looks like it was a nice boat.
http://www.cooperss.com/assetnav.htm...d3d144c47a&P=A
Viper31 is offline
Old 01-10-2006 | 05:39 PM
Viper31's Avatar
Default Re: Ouch! How common is this failure
Spectre cat on there is enough to make you cry. Says rollover damage.
http://www.cooperss.com/assetnav.htm...b5b33e38ec&P=A
Viper31 is offline
Old 01-10-2006 | 05:45 PM
Fountain38SC's Avatar
Cat is the bonefish boat. I think it hapened early last year. very sad.
Fountain38SC is offline
Old 01-10-2006 | 05:49 PM
GOODT's Avatar
talk to brian (sydwayz) his boat did the exact same thing and merc refuses to cover it!!!!!!( bell housing )
GOODT is offline
Old 01-10-2006 | 05:57 PM
SHARKEY-IMAGES's Avatar
OSO Content Provider
Commercial Members
Unhappy Re: Ouch! How common is this failure
It was a nice boat. A friend of mine bought it when it was in like new condition. Had it for a year and then sold it.
The new owner had it for a half a season and apparently hit something out on the river one day.....
Those pics make me sick.....
www.TimSharkey.com/
Digital Photography & Video one BYTE at a time !
SHARKEY-IMAGES is offline
Old 01-10-2006 | 06:03 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I dunno how often it happens, but it sure effn sucks when it does. My boat did not sink, but my gimble broke identical. I was fortunate that my bellows was not compromised. I did not take on one drop of water. As you can see, there is also no visible impact damage to the boat/drive. My drive came down and out of the coupler when I came to a stop. It broke while under way, and slipped out of the coupler once forward motion stopped, and the prop was no longer holding the drive to the boat.
Sydwayz is offline
Old 01-10-2006 | 07:23 PM
Semper Fi's Avatar
What a SHAME!!! I always liked that Powerplay
Semper Fi is offline
Old 01-10-2006 | 07:30 PM
rbtnt's Avatar
I think I almost ended up with a drive like that at the Lake Cumberland Poker Run last year.
After the run, we joined some friends back in a cove and was swimming around checking out the back of the boat. I found a loose hinge pin in one of the gimbal rings. Both screws came out of one of the pins and it was pinched agianst the case. If I had turned the drives one more time the wrong direction, the pin would have fallen out. That would have been real ugly at 100+mph. While we were still anchored, I took a screw out of one of the other pins and 3 of us managed to get the pin wiggled back in and secured with a screw. Needless to say, once I got home, I removed all the hinge pins screws and reinserted them with loctight.
I now carry spare screws and check the pins every time I get out of the boat.
Does anyone know if this is a common occurrence? You might never know if the pin comes out and your drive breaks for no apparent reason.
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 01-10-2006 | 08:17 PM
Viper31's Avatar
Man that sucks Brian. Glad you did'nt lose the bellows and start taking on water. If there was no damage from an impact, what could cause this other than a weak of flawed casting? Could this be caused by improper assembly procedures when the transom assembly was built. Merc would not warranty this problem?
Viper31 is offline
Old 01-10-2006 | 08:30 PM
Dock Holiday's Avatar
Charter Member #34
Saw this happen on a Top Gun we were running with on a poker run last year. He was lucky the drive did not fall off.
Attached Thumbnails Ouch! How common is this failure-dsc07019.jpg   Ouch! How common is this failure-dsc07015.jpg   Ouch! How common is this failure-dsc07017.jpg
Dock Holiday is offline
