what would you rather have??? >
Old 01-11-2006 | 06:17 PM
Default what would you rather have???
On a 1985 27 Excalibur with a stock 502 EFI which drive setup would you rather have:
1) TRS w/ BW trans model 10-17-016
or
2) Bravo
jdub is offline
Old 01-11-2006 | 06:36 PM
GOODT's Avatar
Default Re: what would you rather have???
no question bravo !!!!!!
GOODT is offline
Old 01-11-2006 | 06:38 PM
Too Old's Avatar
The Bravo's going to be faster, lighter and easier to get parts for.
Too Old is offline
Old 01-11-2006 | 06:43 PM
Thats what I've been thinking. I got the motor, trans, gimble and everything else out of the bilge and I was thinking maybe I should just fill in the transom and do the conversion. But on the other hand everything with the current set up is working fine.
jdub is offline
Old 01-11-2006 | 07:03 PM
Thumbs up Re: what would you rather have???
Says it all!
Edward R. Cozzi is offline
Old 01-11-2006 | 07:15 PM
CAP071's Avatar
BRAVO THE BRAVO I must say
CAP071 is offline
Old 01-11-2006 | 07:43 PM
Thanks guys, just had to hear it from somebody else!
jdub is offline
Old 01-11-2006 | 07:44 PM
CAP, I'm about 30 minutes from Philly. Where do you boat?
jdub is offline
Old 01-11-2006 | 07:52 PM
marinetrans's Avatar
Best set-up is the Bravo,but I like the smooth shifting of the Borg-Warner.Too bad its not a 10-18 model w/ 2 more friction plates in FWD. and 1 more friction plate in REV.
marinetrans is offline
Old 01-11-2006 | 08:31 PM
Wink Re: what would you rather have???
If your later model Bravo is hard to shift, it could be the shift cable adjustment. It will probably never be as smooth as the BW, but it can get close.
