Correct props >
Correct props
Correct props
Old 01-13-2006 | 09:42 AM
Default Correct props
I recently purchased a 1990 31' Wellcraft Scarab Excel w/twin 454 mag Bravo 1's. Currently, the engines only max out at around 4100 RPM. The drives have 23" Mirage 3-blade stainless props. My two questions are 1)What is the correct WOT for a 454 mag and 2) Is it possible that my prop size may be too large?
Also, what are the other possibilities as to why my engines are only hitting 4100 RPM? To me, the prop size doesn't seem as though it's too large for this boat/engines, but maybe I'm wrong??? Is there any sort of rev limiters that could somehow be set too low??
24Baja is offline
Old 01-13-2006 | 10:26 AM
Re: Correct props
Go to the prop section and get in touch with Throttle Up they will get you where you need to be.
Badtoon is offline
Old 01-13-2006 | 11:51 AM
LostinBoston's Avatar
Default Re: Correct props
When my 525 was only getting about 4000 RPM it turned out i had a bent valve and a leaky head.
LostinBoston is offline
Old 01-13-2006 | 12:06 PM
bobbarker's Avatar
Re: Correct props
24Baja,
Check your rev.limiters if you have them,make sure their both set the same probably 5200. next check an make sure the
throttles are pulling the carbs. all the way open unless you have fuel injection. You stated you have 23 in. mirage props. but what pitch? Check with your local prop. shop they should help you out as to what dia. an pitch you should be running.
bobbarker is offline
Old 01-13-2006 | 12:21 PM
Rookie's Avatar
I have a friend with a 89 scarab panther with the I think 365's he turns them at 4600 with 23's. 23" is the pitch.
Oh yeah! welcome to the SCARAB Family!
Rookie is offline
Old 01-14-2006 | 04:33 AM
East Coast B's Avatar
I'd have to agree that those props are right around where you need to be. There must be something else going on. I've got a 31 sonic with the mags and the 23's are the ticket. I assume your trimming it out correctly and not running drives all the way in. Agree, check throttle pull range on motors.
East Coast B is offline
24Baja
5
06-20-2005 06:02 AM
Onepass31
03-14-2005 07:48 PM
Elite Marine
4
03-04-2003 05:59 PM
alj
15
04-23-2002 09:27 AM
Kentz
11
02-06-2002 06:31 PM
