Go Back  Offshoreonly.com > Owners Forum > Sunsation
288 open with 525 ? >
288 open with 525 ?
288 open with 525 ?
Old 01-14-2006 | 05:41 PM
beachbob's Avatar
Default 288 open with 525 ?
Anyone have this setup I am considering it. Speeds? Anyone fabricated a shell to close the bow? Would appreciate any feed back TX
beachbob is offline
Old 01-15-2006 | 11:09 AM
Liquidsation's Avatar
Default Re: 288 open with 525 ?
Personally I do not have this set up but the 525 package is bad a$$!! You should see mid 70's no problem. If the boat is a newer model then it may have the stepped bottom that may net you another 2 or 3 mph into the upper 70's.
They come with a snap on cover the open bow if that is what you are talking about. I'm sure you could find some one to build one but if you want a fiberglass shell then just buy a closed bow. Were would you store the shell once on the water? Just my 2 cents.
Liquidsation is offline
Old 01-20-2006 | 03:12 PM
TeamSaris's Avatar
Driver-441
Racer
I am a super boat guy but it should run mid to high 70's. That is what a 30 sb will do so it should be close.
TeamSaris is offline
MahopacMarine
Sunsation
31
10-21-2013 11:19 AM
teaguecustommarine
New Products and Member Discounts
11
09-28-2009 05:47 PM
MahopacMarine
Sunsation
19
09-22-2008 07:21 PM
Frankscarab
Sunsation
42
03-08-2007 11:24 PM
DaveSunsation
02-23-2005 12:51 PM
