Anyone make any heavy duty bilge blower hose? >
Old 01-14-2006 | 08:56 PM
BillR's Avatar
OSO Moderator
Default Anyone make any heavy duty bilge blower hose?
I am looking for better bilge blower hose.
I replaced a section while one motor was out last winter. Now I have both motors out, and went to replace the other side. However when I inspected the section I did last summer, I found it already had holes in it and the paper thin pastic material is now brittle.
Who makes better / thicker / longer lasting 3" bilge blower hose???
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 01-14-2006 | 09:01 PM
offthefront's Avatar
Default Re: Anyone make any heavy duty bilge blower hose?
http://www.bakerprecision.com/airduct.htm
Two Ply Fibreglass
Orange Silicone Coated For High Temperature Resistance
Temperature Range
- 75 deg. F to 500 deg. F
(intermittent to + 600 deg. F)
Smoother Bore For Maximum Airflow
Comes boxed in 11 ft. lengths
offthefront is offline
Old 01-14-2006 | 09:51 PM
mwdill's Avatar
what diameter? 4 inch?
mwdill is offline
Old 01-15-2006 | 12:11 AM
Too Old's Avatar
I don't know but I need some too. The Maytag dryer hose on my Hustler is falling apart. There has to be something better.
Too Old is offline
Old 01-15-2006 | 12:21 AM
Audiofn's Avatar
Charter Member #232
Same with me. I always thought that what they use is such a Joke
Put your best foot forward!
Audiofn is offline
Old 01-15-2006 | 12:45 AM
RLW
Home Depot and Lowes sells an aluminum expandable dryer vent hose which is pretty trick. I'm using the 3" variety.
RLW is offline
Old 01-15-2006 | 07:42 AM
Thumbs up Re: Anyone make any heavy duty bilge blower hose?
http://www.mcmaster.com/
Do a search for duct hose, or anything else that you can think of!
Boatfixr is offline
Old 01-16-2006 | 12:22 PM
BillR's Avatar
OSO Moderator
here:
http://www.wynnenv.com/flexible_hose.htm
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 01-16-2006 | 01:20 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Exactly. Home Depot/Lowes aluminum flexible hose found in the venting/pipe section for gas appliances. I'd give that a try. Screw plastic or pvc unless the hose needs to be squeezed or crunched to fit. I use it for my home dryer with no problems.
Reckless32 is offline
Old 01-16-2006 | 01:24 PM
BillR's Avatar
OSO Moderator
Yeah, I saw it too, but in salt air/water - won't it corrode?
Don't need to pull the motors again just to swap out vent hose.
I'll do it right the first time.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
