How much to add switchable exhaust? >
Old 01-18-2006 | 08:45 PM
miamioffshore's Avatar
Default How much to add switchable exhaust?
If my boat already had exhaust , but I wanted to switch both engines to a switchable type, (i.e. captains call etc.) , how much $ would I be looking at? I'm talking total cost here, parts, removal of old exhaust , installation of new, switches on dash, everything?
Thanks,
M
miamioffshore is offline
Old 01-18-2006 | 09:17 PM
CAP071's Avatar
Default Re: How much to add switchable exhaust?
wow that much
CAP071 is offline
Old 01-18-2006 | 09:31 PM
bobonthis's Avatar
why?
bobonthis is offline
Old 01-18-2006 | 09:42 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
depends on if you have thru prop or thru hull exhaust now.
US1 Fountain is offline
Old 01-18-2006 | 10:07 PM
Thru the hull
Old 01-18-2006 | 10:30 PM
FOUNTAINATLAST's Avatar
Originally Posted by miamioffshore
Thru the hull
Do you have a Y-pipe that has been capped off??? If not you'll have to pull both motors to install them as well as the captains call equipment.
FOUNTAINATLAST is offline
Old 01-18-2006 | 10:35 PM
Outdrive1's Avatar
Masher touches my
Originally Posted by rastaboatin
why?
A y pipe is about 500 new, maybe a couple of hundred used on Ebay for big block style one. The silent choice diverters are even more money, probably at least a grand each new if not more, so maybe 5 hundred or so on Ebay. You need an air pump if they are air activated and the switch(another couple of hundred bucks) and you have to pull the motor to install it. So you've got a couple of thousand in parts new, plus labor to install and don't forget you have to r&R your motor and drive to install it. You could save an easy grand or more per motor buying on Ebay.
http://cgi.ebay.com/ebaymotors/Quick...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/MERCR...spagenameZWDVW
Outdrive1 is offline
Old 01-18-2006 | 10:46 PM
Too Old's Avatar
http://www.trickmarine.net/productde...?productid=833
Too Old is offline
Old 01-18-2006 | 10:48 PM
Harper220's Avatar
That sounds like a huge effort and expense to make your boat quiet...
How about just adding some of those Gibson turn down exhaust tips?? Quiet at idle and back to normal when on plane. Much cheaper alternative($500) and their as easy as clamping them on...
Harper220 is offline
Old 01-18-2006 | 10:51 PM
Harper220's Avatar
Here's an alternative.
http://www.teaguecustommarine.com/sw..._mufflers.html
