Deck to Hull ?
When building a new boat how do manufacturers glass the deck to the hull from the engine compartment up to the front of the cockpit ? It seems like once the two halves are mated there is no room to get that section. Do they just use screws or is it posible to adhere it from the outside?
My Baja is bonded with sealant, rivets and screws. The screws that attach the rub rail also go thru the same section.
I also have sections that are nearly impossible to reach trying to get to bolts for cleats, fuel fill etc.... I found some of this out while repainting the boat which we are doing right now.
Re: Deck to Hull ?
On older boats like my 357 in time you will get a lot of front deck flexing at high speeds. I needed a new rub rail, so I went to my fiberglass man . He removed the old rub rail filled the old holes with epoxy, tighten all the screws that hold the deck to the hull, drilled all new holes for the new rub rail an installed new rail, what a difference,no more flexing or shaking at high speeds , boat feels a lot more solid well thats my 2 cents worth .
Mine is glued when the two halves are put together, glassed the full perimeter around the inside and the rubrail is through bolted with stainless screws and nylock nuts. I sure hope my rubrail never needs replacing!
I noticed mine when replacing the rub rail all but about 4 feet on either side was glassed together. I took some SS screws and counter sunk the heads so they wouldn't interfere with the rubrail over them. One every three inches. Should I use some type of epoxy in addition to the screws in this area or just finish up and seal with 5200?
