Effects of stand off boxs
Old 01-24-2006 | 10:02 PM
iamfaster's Avatar
Default Effects of stand off boxs
What effect will stand off boxs have on bow lift and what happens to CG. Moves forward or aft?? I have -2"shortie with 1"spacers. I would like to go with imco nuetral boxs and NO spacers.
iamfaster is offline
Old 01-25-2006 | 07:59 AM
Sean's Avatar
Default Re: Effects of stand off boxs
D,
I am looking at putting Stellings boxes on my Cafe when I repower...so I've been doing soem research on boxes for that application.
I would guess that the pivot point moves aft and probably the CG. I also think that unless you plan on closing up the transom, a nuetral box will not work. Moving the props aft has the same affect as lowering the X, and you'll be able to lose the spacers, but I dont think that will be enough...
Hopefully someone on the board has done this on a Scarab like yours and con offer more than my "I think..."
Good luck...let us know your results.
Sean is offline
Old 01-25-2006 | 08:04 AM
Clay Washington's Avatar
Default MerCruiser Integrated Transom
Have you considered MerCruiser Integrated Transom? It combines a stand-off box and hydraulic steering.
The new I.T.S. features integral power steering cylinders and a lightweight, removable plastic cover which allows access to concealed hydraulic steering and trim hoses.
I wonder if any has a pair of used ones that they will sell me?
Clay Washington is offline
Old 01-25-2006 | 08:42 AM
Sean's Avatar
Originally Posted by Troutly
For the price that Mercury charges for ITS and the benefit you get (or lack there of as in my case), I'd go with Stellings.
ditto
Sean is offline
Old 01-25-2006 | 09:05 AM
gsmith9898's Avatar
I have the i.t.s. and it is great. Very clean set up. Worth the extra money in my opinion to have the steering rams sucked into the side of the drives.
gsmith9898 is offline
Old 01-25-2006 | 09:19 AM
Harper220's Avatar
IMCO is a very popular brand when it comes to extension boxes. They have an optional 3" lift with 12" setback and they're very reasonably priced (under $2000).
Harper220 is offline
Old 01-25-2006 | 03:05 PM
Titan's Avatar
I have the Imco Standoff Box and 2" shorty drive. The Imco set up is much beafier than the Mercury set up. Sorry I do not have any pics.
Not too mention the steering comes off the transom assembly which keeps the transom neet and free of clutter like the above Mercury set up..
Titan is offline
Old 01-25-2006 | 03:35 PM
Heres a pic of the IMCO's... this is the only one I have on this puter.
Iamfaster, Yes...You should be able to take out the spacer when you mount the boxes.
I have the -2's on neutral set backs with a non stepped bottom.
Back4More is offline
Old 01-25-2006 | 10:16 PM
iamfaster's Avatar
Sean, good luck with your project..did you start yet? i didnt completely spend my kids college fund on the motors and drives.....although looking for used..
I would "think" your hull would benifit from boxs as well. It would b nice to see the CR this summer. I called a couple of 38' scarab owners who added boxs. Improved handeling as far as running flatter off swells, but both added HP at same time, so couldnt get idea if boxs helped speed.
Why would i have to close up transom holes with the imco's? I think you may be right as far as 1" less(no spacers) may still leave drives a little deep. Maybe Stellings.
Anybody know if bow lift increases with set-back?
Titan.....where r those pics??
Old 01-25-2006 | 10:31 PM
HuntingtonBeach's Avatar
If one had the choice between using ITS/XR's or Stellings/XR's or IMCO is there a reason to go with one or the other all dimensions being equal? I was under the impression that the ITS set up was similarly priced to the others?
HuntingtonBeach is offline
