"Carry-On" Air Conditioning >
Old 01-25-2006 | 11:19 AM
Clay Washington's Avatar
Default "Carry-On" Air Conditioning
Has anyone tried one of these?
Carry-On A/C
Completely self-contained, 77 pounds, and runs on "dockside" power.
Clay Washington is offline
Old 01-25-2006 | 11:25 AM
wstultz's Avatar
Social Distortion
Default Re: "Carry-On" Air Conditioning
We had one in the mid nineties that we used on a 32 fountain and a 31 bullet. It will freeze your ass out of that cabin. It doesn't always seal properly but that didn't really matter.
wstultz is offline
and thus the money pit begins.........
dreamer is offline
Old 01-25-2006 | 11:33 AM
I know, I know...
Old 01-25-2006 | 11:35 AM
scottc's Avatar
A great unit. It will leak in the rain sometimes. It will FREEZE your a$$ off. Go with the bigger one. Can be found on ebay and other boating sites. Great resale value can be had from $350 and up.
But the best thing is an installed system by far. If you are going to keep the ride for a while go with a permanent system.The carryon will get bounced around when getting big air!!!!
scottc is offline
Old 01-25-2006 | 12:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I have used that same unit. It is pretty darn cold. The worst part about it is slinging it up onto and off of the bow each night/morning. Its heavy and awkward.
Several of us here in the local area have been buying small 5000-6500 btu normal home window air conditioning units (45-55 lbs), and placing them in the cabin access door to the cabin (on the floor), only when needed. You can obtain a nice 3-4" thick piece of foam from a local upholsterer to fill the rest of the cabin door opening. It works well, and its cheaper.
However, after a year of using a portable AC unit as described above, I plan to install AC inside the boat this year. Its quite the hassle to have to deal with a portable. If you need AC (which you do in TX); Clay bite the 'Bullet' and put in a permanent mount unit. Its TOTALLY worth it.
Sydwayz is offline
Old 01-25-2006 | 01:38 PM
HiPerf2000's Avatar
I had one. lasted me 10 years and 4 different boats. Sold it to a friend when i installed air in the 35. Still works good for him.
HiPerf2000 is offline
Old 01-25-2006 | 01:45 PM
BajaRunner's Avatar
PM Liquid Asset on the board. I know he had one for sale awhile back.
BajaRunner is offline
Old 01-25-2006 | 03:07 PM
OSO's Avatar
OSO
We have just taken on another advertiser that provides Outerlimits and Nor-Tech with their 12v air cond systems. Hold off before purchasing and I will post the information shortly.
OSO is offline
Old 01-25-2006 | 03:52 PM
OSO's Avatar
OSO
http://www.bayairac.com/
OSO is offline
