warmed up hp500's should i change the jets in the carb's? >
Old 01-27-2006 | 08:00 AM
BajaRunner's Avatar
Default warmed up hp500's should i change the jets in the carb's?
My boats ready to go. Heres what we (bobl) did to the carb'd hp500's
Bowl Blend heads, port exhaust side
crane 731
Raise rev limiters to 5600
mill heads .020 with cometic .027's
I am hoping for ~575hp. Should the jets go up a size or 2 or is the motor rich enough stock to support this?
BajaRunner is offline
Old 01-27-2006 | 08:14 AM
jryan26's Avatar
Default Re: warmed up hp500's should i change the jets in the carb's?
Good question. Are you going to dyno them?
jryan26 is offline
Old 01-27-2006 | 08:17 AM
BajaRunner's Avatar
no, they are already back in the boat ready to go-
Old 01-27-2006 | 02:11 PM
no way to know about jets because no one knows if you where correct in what you had in the first place.... need to do egt's to know for sure or spend a long time trying to read plugs....
dyno should have been on your list of things to do before installation...
stevesxm is offline
Old 01-27-2006 | 02:43 PM
Nordicflame's Avatar
BobL has a nice LM-1 O2 setup. Bung(s) in the exhaust would be very helpful here and get you where you want.
Bob will get her right
Dave
Nordicflame is offline
Old 01-27-2006 | 03:15 PM
baja36ft's Avatar
crane 731
IF YOU REV IT TO 5600 THE STOCK 800 CARB IS TO SMALL
I WOULD GO WITH A 850 OR JET THE 800 UP SOME
YOU SHOULD HAVE 81,75,93,89 I WOULD GO 85,79,97,93
HOPE THIS HELP. ARE YOU USING A CARB SPACER?
baja36ft is offline
Old 01-27-2006 | 03:26 PM
BajaRunner's Avatar
Havent done the spacers yet. we were going to see what it does first.
Old 01-27-2006 | 05:24 PM
baja36ft's Avatar
If You Go With A Spacer Some Times It Leans The Carb Out And Need To Go Bigger
baja36ft is offline
Old 01-27-2006 | 05:27 PM
axapowell's Avatar
Where To
Still using the 800 cfm Holley on my HP500's Changed the heads to AFR CNC'd 315cc, Crane 741 and Dart 6200 intake 1" HVH SS plate and had to jet down to get the correct A/F an BSFC on the dyno. Made the jets :
Primary: Starboard 71, Port 77
Secondary: Starboard 83, Port 87
Hope this helps,
Dave
axapowell is offline
Old 01-29-2006 | 06:40 AM
I need an education, why do you recommend 4 different size jets in a carb? I have a 625 hp n/a 540 with a 950 quick fuel carb, jetted 86/86 front, 90/90 rear. How do you determine what jets to use? I think that I am lean at part throttle, before the secondaries come open= engine will start to miss at times at cruise on primaries.
Nova 26 is offline
mtgbiker
34
06-15-2006 08:39 AM
BajaRunner
4
03-02-2006 06:23 PM
