GM Crate Motors as drop in's for boat >
Old 01-29-2006 | 07:03 PM
dean51267's Avatar
Default GM Crate Motors as drop in's for boat
I know I have seen this issue brought up, but I can not find it.
Can you use a GM crate motor as a mercruiser replacement motor? Most directly I am looking for a pair of 502's to replace a pair of low power 454's.
Thanks for letting me pick your brain and for helping the not-so-technically savvy...
dean51267 is offline
Old 01-29-2006 | 07:12 PM
375stinger's Avatar
Default Re: GM Crate Motors as drop in's for boat
check peak engine rpms (might need to change cam, not sure), also will need a marine carb, flame arrestor, etc, and probably a few other things. im no specialist at all, just telling some of what ive picked up over the years
375stinger is offline
Old 01-29-2006 | 07:13 PM
offthefront's Avatar
get ready for all kinds opinions ... but generally most would say no ... at least not right out of the box ..err crate ... wrong cam ...brass freeze plugs.. and some clearances are not right for marine use ...However ..If I was to usea crate motor. I would take it to someone I can trust than can go thru the motor and Make the necessary changes ..m
offthefront is offline
Old 01-29-2006 | 07:36 PM
cuda's Avatar
There is a reason Mercruiser's engines are so expensive, they are worth it!
cuda is offline
Old 01-29-2006 | 07:44 PM
Pat McPherson's Avatar
The cam in a 454 or 502HO is OK but not great for marine use. Also, I have heard that the tolerances are not held as tight in a "crate engine".
1-800-runsnew sells brand new 435HP/502 marine base engines for the same or less than a 502HO crate engine; like $5200...
Patrick
Pat McPherson is offline
Old 01-29-2006 | 08:03 PM
32storm's Avatar
Will need to change the oil pan, as the crate motor is smaller than the marine version. Cam is different, but some have run it without issue. Waterpump different as well. Internally, same components as marine version on lower end.
I'm sure others will chime in with other differences as well. Can be used, but will need a few changes.
32storm is offline
Old 01-29-2006 | 09:30 PM
search this fourm for a thread called "ZZ 502 DUD questions".....check that out.......it will help you make up your mind......doug
pullmytrigger is offline
Old 01-29-2006 | 10:40 PM
I had a pair of 502s from www.1800runsnew.com and they were great!
Pure Energy is offline
Old 02-04-2006 | 03:28 PM
Food for thought!
What has GM ever put the 502 in? Nothing I can think of.
Where do all of these 502s go? Mostly the marine industry!(?)
Note: Some things a different for safety reasons but mainly in the ignition, alternator, and carb areas because of the inclosed engine compartments and flame/spark/fuel control.
Get a merc shop manual and a GM shop manual for the big blocks and compare specs. For the most part they are the same. And yes even some DO use the same cams. Some do not.
Merc.$$$$$ GM $$
Just have to be aware of what the real differences are.
GETTINBYE is offline
Old 02-04-2006 | 05:22 PM
satisfactionII's Avatar
Everything I 've read says GM Crate motor to drop in boat = no. The 1800runsnew stuff look like the way to go on that.
satisfactionII is offline
