Merc 525sc water crossover
I am installing water crossovers on my 525sc's. How many of you with these motors run water dumps? Boat runs 90 now, will I have to much water pressure with out dumps? Bravo 1 drives w/dual water pick-ups. Not running t-stats. 1" plumbing.
Thanks for the info.
Originally Posted by RLW
Only way to know is to install water pressure gage.
Too much pressure requires a relief device.
My buddy sees between 5 and 15psi depending on rpm. He has a dash mounted water pressure gage. The water temp is still quite cool at these pressures.
Before he added the dumps, the water pressure was 25+psi and the engine ran way too cold with condensation all over it.
Patrick
Patrick
Originally Posted by Pat McPherson
Absolutely...
I think I may end up sticking with my circ pumps. My engine man says my motors will not warm up to temp until running WOT. Then dropping down to idle loosing heat and causing condensation in motor,"continueously "thus shortening engine life. Sounds like alot of headache and money for a few extra ponies and looks.
I may have a new set of crossovers for sale!
Originally Posted by DRIPPINWETII
I think I may end up sticking with my circ pumps.:
10-15HP is not worth the effort IMO.
The only down side to the circ pumps, that I can think of, is that they don't last real long (100-150hours) when they are run over 5000rpm.
Patrick
Patrick
