Top Speeds For Kaama Surface Drives
Looking For Speed Numbers As Well As Prop Size And Gear Ratios On Anything Running With Kaama Surface Drives. I Am Currently Spinning 18x30 At 5400 With 8% Overdriven Gears On A 1983 302sr1. Looking At Possibly Upgrading Hp
88.9 Gps # On Flat Water, Poker Run Last August. Not Much In The Water As Far As Steering Goes. Sure Had Some Scratching There Heads Wondering What That Old Turd With A Square Windshield Was Doing Up Front. It Was Fun Anyway!!!!!!!!!! Am Adding Ponies But Conserned With The Steering. I Only Have Single Ram On Starboard Side , Like I Say Loose On Steering.
Check with Galen at Speedmaster. He showed me one he had there. I think that sixes and 3A props fit them. He'll know for sure.
333 North Adelle Avenue, Deland, FL 32720
(386) 734-3133
Email: speedmastersbellsouth.net
(386) 734-3133
I am running a 1987 311 with Kaama's and 375 hp. The drives are 1:1 with twin disc 502 tranny, props are 16.5 x 26 (I think, gotta check). Runs around 68, and handles great. I do have the newer Kaamas with the high mount for the trim cylinder and daul ram steering. I have always wanted to repower, sounds like yours runs great.
I saw a thread a while back about drive boots, anybody find some? Mine are good now, but just thinking ahead.
I am running a 1987 311 with Kaama's and 375 hp. The drives are 1:1 with twin disc 502 tranny, props are 16.5 x 26 (I think, gotta check). Runs around 68, and handles great. .
Mine has the dual ram steering also.
Just shy of 4900.
Have you had any prop problems, mine are original Kaama wheels. I keep hearing of guys loosing a blade. I have only sent mine out once to have them checked for cracks.
