B&M BLOWER
What Can You Guys Tell Me About A 454 Bulldog With L88 Heads And A B&m Street Blower. About 500hp. Reliability, What Should I Look For While Test Driving. How Many Hours Can I Expect Before A Rebuild. Motor Has 240 Hours On It And 20 On The Blower. Thanks In Advance For The Help.
It Was Stock 454/b1 1990 Henry Keller Added The Blower And The L88. The Boat Is A Great Price. Just Dont Want Problems.I BELIEVE IT IS A BULLDOG COPY BUT THAT IS WHY IM ASKING YOU GUYS.
The only L88 I know of are the aluminum rectangular port heads used on late 60's corvettes. Kind of old tech.
BTW, you cant turn a 454 into a 540 bulldog. Different blocks.
Get full specs, block and head codes, type of blower, crabs, cam, etc... Then someone here can probably give you good info.
Gary
Gary
Gary
Gary
Get the cam specs, the compression ratio, model of blower, blower pulley ratio, psi boost @ rpm, engine block #s, head #s, ask if the carb is boost referenced, and make sure all the accessories are USCG approved (fuel pump, flame arrestor, alternator, starter, etc).
I've never been much of a fan of the L & S extension boxes. And note bravos are not the strongest drives for a blown engine. Check the gimbal for play too.
Gary
Gary
