My engine is "hunting", but Im not blown. >
Old 01-17-2002 | 02:36 PM
NICKSLICK
Post My engine is "hunting", but Im not blown.
My port engine sounds just like a blown engine, but I dont have a blower!
You know, it sounds like one cycle is lower than the other...
It only does this after a good run...
Any ideas?
Old 01-17-2002 | 02:51 PM
packinair
Post
Nick the only option I see is to slap a blower on it and call it good
Old 01-17-2002 | 03:31 PM
NICKSLICK
Post
You guys are a big help!
NOT!
now BEAT IT!
Old 01-17-2002 | 03:46 PM
Scarab3DMC's Avatar
Post
Timming chain mabe?.. distributor bearing? vacuum advance springs
Scarab3DMC is offline
Old 01-17-2002 | 04:02 PM
NICKSLICK
Post
all three of those things sound expensive...
Old 01-17-2002 | 04:03 PM
Hot Boat's Avatar
Team Dysfunctional
Post
The fun never stops for you does it. Look to see if there is something by the air intakes that would make it sound funny. Maybe a loose hose or something. Try spraying some carb cleaner or brake cleaner on the belts when it is running. if the sound goes away for a minute, tighten or change the belts. Is it running fine other wise
If it aint broke .... I can break it....
Hot Boat is offline
Old 01-17-2002 | 04:07 PM
Caincando1's Avatar
Post
Insure it and sink it. Oh wait you already thought of that.
Caincando1 is offline
Old 01-17-2002 | 04:08 PM
Gordo's Avatar
Charter Member #94
Post
Assuming these are not efi motors, how about a partially sinking float?
Abby-someone
Gordo is offline
Old 01-17-2002 | 04:24 PM
OldSchool's Avatar
Post
Its all about ball bearings
OldSchool is offline
Old 01-17-2002 | 04:31 PM
Niuhi's Avatar
Charter Member #971
Post
Nick if that things sounds like a gear driven blower I would definetly check a timing chain. One of the last things you want to go on you.
Les
Hawaii no ka 'oi
Niuhi is offline
