General Rules on Power and Pitch >
Old 02-03-2006 | 10:10 PM
dean51267's Avatar
Default General Rules on Power and Pitch
Okay, I need help from the prop masters again....
I guess there is a correlation between prop pitch and horsepower, or is there?
If so what pitch can a pair of 430 hp motors turn?
Or is far more complicated than this?
I am trying t oget into the mid 70's and if I could turn a mega pitch prop it would be easy, but apparently that is not the case.
So what is the correlation between pitch and horsepower? Is there a general rule to follow?
Next is cleaver props, when are they approperate? What do they do differently than others?
Thanks for the education....
dean51267 is offline
Old 02-04-2006 | 06:53 AM
Default Re: General Rules on Power and Pitch
the more horsepower you have,the more pitch you can run on any given boat. I had a searay 20 foot boat with a 400 hp 383 and could turn a 21 pitch 4 blade prop at 5300 rpm. I now own a 26 foot boat with a 625 hp engine and can turn a 4 blade 5100 rpm. Many factors in finding right pitch, hull type, boat size/weight, rpm you want to turn your engines at, 3,4,or 5 blade prop, gear ratio in the drive,how high above sea level you boat, fresh or salt water, etc.
Nova 26 is offline
Old 02-04-2006 | 09:11 AM
throttleup's Avatar
There is a correlation between speed and power but there really isn't one for power and pitch.
There are so many factors that pitch doesn't really tell us how fast a boat will go. There are times when we deal with a certain type of boat with a given power, then we can guesstimate a pitch. For the most part pitch doesn't determine the speed.
There are 3 factors that will determine the pitch prop you need to run;
WOT rpm- this is determined by the design of the motor and is typically where the motor makes max horsepower
Drive/transmission gear ratio- these can vary widely and have a large bearing on prop pitch.
Hull- Depending on the hull design and weight this will influence how fast a boat can go.
There are other factors such as the number of blades, drive height, customers goals and design of the prop.
The pitch that is marked on a prop can be several inches off of what the true pitch is.
To determine a starting pitch one would need to know the desired WOT rpm, drive/transmission gear ratio, and length/design/weight of the boat. With this information the proper prop pitch can be determined within a reasonable range.
Matt
throttleup is offline
throttleup
General Racing Discussion
0
03-10-2006 06:04 PM
Pete B
0
02-14-2006 07:38 PM
VeeCat
Hustler
33
07-19-2005 09:39 PM
Steamin Rice
2
09-28-2004 05:15 PM
Risk Taker
02-04-2003 10:27 PM
