Rebuild Gimbal - Special Tools?
Are there any special tools or "secret" procedures required to replace the gimbal bushings for up/down tilt and left/right steering?
I've got the transom assemblies off the boat so it looks pretty straight forward.
Thanks,
Jeff
Thanks,
Jeff
GIVE ME MORE INFO year model ect and Ill pull up the page from merc but you are better off just letting some one with exp do it.... tools you will need depending on model are hinge pin tool,tourqe wrench, bushing installers/ drivers, steering pin kit ect......
make shure you follow the directions to the tee or you could end up with major problems It is not as easy as it looks although alot easier with the assy off the boat
Better Be Careful Putting Pages From Merc Shop Manuals Or Service Bulitens On The Internet Mercury Sued A Guy In Florida Last Year For Doing That. Their Basis Was Copyright Infringment. I DONT WANT TO SOUND LIKE A PRICK JUST WANT TO HELP AVOID PROBLEMS
Nothing a Clymer’s repair manual can’t help you with. Cost about $35
For the complete mercury parts diagrams along with part #’s same as the microfeesh the dealers have go to http://www.mercruiserparts.com
If it aint broke .... I can break it....
One of the tools you actually can't live without is the driver for the plastic insert that holds the water hose. Ive pretty much made all my own over the years. Transom assembly is not too bad. The upper swivel shaft bushing can be fun as it is blind but there are a couple tricks for that.
DaveP
01-24-2002 12:38 AM
