Stereo guys-A little help needed >
Old 02-06-2006 | 08:58 PM
OldSchool's Avatar
Default Stereo guys-A little help needed
I started installing a new stereo system in my boat today and I'm having a little problem. I can't seem to find the crimp-on small connectors for the speakers. I went to BestBuy, Tweeters, Radio Shack, Home Depot, Boat US and West Marine. Nobody has them!!!!!
Can someone mail me some of them or let me know where I can order them online???
OldSchool is offline
Old 02-06-2006 | 09:13 PM
Outdrive1's Avatar
Masher touches my
Default Re: Stereo guys-A little help needed
Most any stereo shop should have them, are you talking about the connectors that are half the size of a regular connector usually used on a negative terminal of a speaker? Just put a full size one on there and crimp a little first so it's nice and tight. Either that or you can solder a wire on there and heat shrink it. I honestly prefer soldering most of my connections, just get a butane soldering gun and it will make your life alot easier.
Outdrive1 is offline
Old 02-06-2006 | 09:22 PM
OldSchool's Avatar
I was told to never solder a wire to a speaker terminal. It can mess up the speaker. It is the small connectors that I need for the negative terminal.
Old 02-06-2006 | 09:26 PM
buck183's Avatar
I can mail you a bag of them if you want. We order them by the hundreds. I know what you're talking about.
I have been guilty of putting the full size one on a time or two myself using the plier method. For your applicatioin I probably wouldn't want to do it though.
I wouldn't solder if it were mine either.
Buck
buck183 is offline
Old 02-06-2006 | 09:29 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Have you tried an auto stero shop that installs them? I bought the speaker wire kits before that had them already crimped on.
On that note, I've never had a problem soldering them on. Guess I don't see how it can be damaged since the speaker itself is soldered to the terminal. You're not appling voltage, just some heat.
US1 Fountain is offline
Outdrive1's Avatar
Masher touches my
I guess if you aren't confident in your soldering abilities I would refrain from doing it, you can end up un-soldering the speaker leads if you don't watch what you're doing. Sounds like Pedro will hook you up. About time you did something Buck.
Old 02-06-2006 | 11:25 PM
I found mine at WalMart in the car audio section. I would never had thought they would carry them. If I remember right they are even gold plated.
Mikey Likes It is offline
Old 02-07-2006 | 06:53 AM
BillR's Avatar
OSO Moderator
Any car stereo install shop will have those. Also the larger size that has been crimped to be real tight works 100% fine too.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 02-07-2006 | 07:10 AM
OldSchool's Avatar
Thanks guys. Buck is mailing me the right ones. I just don't like to do things half-azzed.
Old 02-07-2006 | 07:23 AM
Mike Paula's Avatar
You guy ever try soldering tab? I get them from radio shack and you wrap it around the wire and run a bic liter under it. I love them the work well and you’re not using a lot of heat to damage other components
Mike Paula is offline
