Pocket Porting >
Pocket Porting
Pocket Porting
Old 02-07-2006 | 06:57 PM
paradigm shift's Avatar
Default Pocket Porting
Having a set of heads rebuilt and do not have money to have them professionally ported. Couple of questions maybe you guys could help me with and keep me going in the right directions.
502 with stock rect port heads fitted with 2.25 intake and 1.89 exhaust valves. Is it worth it for a home builder to pocket port and do some blending to help flow. I thinking minor work here nothing major from what I have read. Sometimes less is better than more.
I am also looking for all the information I can get on exactly what and what NOT to do. I have some information but more is better. Pictures are worth a thousand words as someone once said. Thanks if you can help.
paradigm shift is offline
Old 02-07-2006 | 08:24 PM
GNJ's Avatar
GNJ
Default Re: Pocket Porting
I have rect. heads on my Gen 6 502's as well. Most of the articles I have read on rect. heads mention to clean up the exhaust side and leave the intake runners alone. When I took my heads off to have a valve job, I noticed alot of rough casting inside the exhaust bowl that could stand to be cleaned up which had the potential to create turbulence. Also, the exhaust pocket I expanded out to allow more flow of the exhaust gases. You can also clean up the short side radius and blend in as well. Easy - but be carefull that you blend and not gouge out too much. I wouldn't do anything to the intake runners. Gary
GNJ is offline
Old 02-07-2006 | 08:28 PM
If you are talented with a die grinder it is beneficial to do bowl port work. You can mildly clean up the intake bowl under the seat area. I would suggest positioning your seat with layout fluid so you do not get into it. Have you machine shop set the heads up so you know what not to grind. Keep a .030-.050 margin away from the 45 seat. Basically you want to remove excess material and shape bowl short turn. The exhaust pocket with net the most gain. The short turn side of the ex.bowl is very peaky. This side needs to be formed into a radius . Keeping consitricity and shape are very important. If done wrong you can actually go backwards. Do not touch intake runners at all.
Dean Gellner
mrhorsepower1 is offline
Old 02-07-2006 | 10:25 PM
Thanks for the replies. You have confirmed my other research and confirmed my less is more comment. I am handy with a die grinder. I was thinking of just some cleaning up and work some on short turn radius but I do not want to get carried away and remove too much and hurt the flow. I have a couple of books that show some pictures and describe in some detail what you are supposed to do.
Recommendations on chambers other than stay away from spark plug holes - threads and valve seats? Thinking of de-burring - polish and cc them while I have heads a part.
Old 02-08-2006 | 12:50 AM
Strip Poker 388's Avatar
Rob
There are some picks on my thread.
http://www.offshoreonly.com/forums/s...t=500efi+build
Strip Poker 388 is offline
Old 02-08-2006 | 08:47 AM
I have done a couple of sets myself on BBC. Look at the Standard Abrasives website, they have some good tips and you can buy their kit through Summit. I start by Gasket matching the Intake with the Heads and then work my way back not removing more metal than needed.
jeffswav is offline
Old 12-04-2007 | 06:11 AM
Registered User
tptools.com has some nice long-reach burrs and other abrasives. Good pricing too.
Chris Sunkin is offline
Old 12-04-2007 | 06:57 AM
Who has the long reach die grinders?
excalibur32 is offline
Old 12-04-2007 | 07:53 AM
Rob
Originally Posted by Strip Poker 388
Heres the grinder I used ,its cheap but works
http://www.harborfreight.com/cpi/cta...emnumber=93621
Attached Thumbnails Pocket Porting-heads%25201-22-05%2520005%2520%2528small%2529-small-.jpg
Old 12-04-2007 | 08:01 AM
http://store.summitracing.com/partde...5&autoview=sku
this should work for you . it's the mandrel length , this kit has a 4" which should work ok..
you can also buy the cone shaped abrasives at summit too...
open87 is offline
