New exhaust question >
Old 02-08-2006 | 08:14 AM
satisfactionII's Avatar
Default New exhaust question
I just ordered a new exhuast system for my 502 MPI. The parts are the Gil manifolds with Hardin Marine riser and tailpipes. I am also going to use the Hardin Marine Cyclone switchable mufflers. Will I need to reprogram the ECM?
satisfactionII is offline
Old 02-08-2006 | 08:41 AM
Default Re: New exhaust question
Most do not require reprogramming for that mod. That is what I've been told by several qualified engine builders. I too have 502EFI's with aftermarket cast manifolds ( Stainless Marine ) and many other mods. Stainless Marine is my preference for this type set-up though. The riser-manifold joint allows for much more lattitude for installation alignment if you by chance are going through transom with your pipes. I'm guessing performance is about the same on either one. Not a significant change in mph. The only thing I've seen on the Gil is that the plugs are pretty hard to get to on the inside bank between two motors. Although there is not a significant change in mph, I strongly believe in this type of addition if only because of the elimination of the through joint water passage and the heavy, rusting steel. They do sound nice also.
deboatmon is offline
Old 02-08-2006 | 09:01 AM
madbouyz's Avatar
When I upgraded to S/S exhaust and better breather it was recommended to install the 'vortec' fuel pressure adjuster to bump the fuel pressure up .
I got mine from Teague ...
madbouyz is offline
Old 02-08-2006 | 09:25 AM
JasonSmith's Avatar
I'm in the process of adding Dana exhaust to my boat. Well, I've ordered it anyway... I am having the ecms done just to get the rev limiters bumped to 5400 RPM. I am also adding the fuel pressure regulators for a little bump.
JasonSmith is offline
Old 02-08-2006 | 12:44 PM
Thanks to all for the input. I was hoping that the engine would at least run after these small mods... know what I mean.
Thanks again.
hpy540
8
11-22-2005 07:14 PM
THE GOOD STUFF
03-03-2004 09:17 PM
formula1
05-25-2002 07:59 PM
thisistank
Baja
17
03-24-2002 10:50 AM
