Thermostatic oil cooler? >
Old 02-12-2006 | 01:44 AM
Default Thermostatic oil cooler?
HELP!!!Was getting ready to purchase a t-stat oil cooler, but notice the Merc. oil filter adapter shows one internally? My oil temps are too low(<170 cruising, 200 deg. after long WOT pass) and I'm getting excessive condensation in motor. It is a '97 HP500 with 3.3 Whipple, no cooling system t-stat, just 5/8 restrictor disc. and crossover. Rear of intake tapped to bleed off water. Oil pressure 60 lbs. max.,35 at idle. Head gaskets good, and no mechanical issues with motor.
I boat in the NW, usually cold water temps and 70-80 deg. ambient.
Engine also runs very cold, usually will barely register on gauge, and yes it works.
Should I bring cooling system temps up, thereby raising oil temp? I could plumb the stock check balls and tee back in.
Or should I just address oil temp? Shouldn't the Merc. oil t-stat be working? I have disassembled the oil filter adapter and I'm going to test the t-stat plunger.......
HP350SC is offline
Old 02-12-2006 | 02:21 AM
RLW
Default Re: Thermostatic oil cooler?
I would try some thermostats first. 142 and 160. It definitely helped me during the late season runs. I run a crossover with bypass, and 160 T-stat has three holes in it. Holes are .155"
Do you have milk under the valve covers?
RLW is offline
Old 02-12-2006 | 11:21 AM
Yes, pretty milkshaked. I have a bung on top of crossover, I could put the Merc. tee w/check balls on, and a thermostat in the housing.
HP350SC is offline
Old 02-12-2006 | 02:15 PM
RLW
Crossovers can be a pain. I have been through the ups and downs.
Dean Nickerson clued me in on my current setup and it is successful. My crossover is a Stainless Marine. I usually run a 142 T-stat with (3) .188" holes, for the warmer months. I do use a Mercury Racing Oil T-Stat filter mount, also.
RLW is offline
Old 02-12-2006 | 02:40 PM
TC's Avatar
TC
RLW, If you have a bypass what is the purpose of the 3 holes in the thermostat?
TC is offline
Old 02-12-2006 | 02:46 PM
I would say to keep steam pockets from forming. My motor tilts back a ways, I will probably do a 3/16" hole at top of t-stat.
HP350SC is offline
Old 02-12-2006 | 04:05 PM
RLW
Yes, the (3) holes help keep some flow of water through the block so steam pockets do not form. That is what I have been told.
The bypass maintains a supply of water flowing to the exhaust manifolds.
HP350C,
I do not know what one 3/16" hole is going to do for you. Try it and let us know how you make out.
RLW is offline
Old 02-12-2006 | 04:43 PM
TC's Avatar
TC
That makes sense.
TC is offline
Old 02-13-2006 | 06:35 PM
Took apart my oil filter adapter and tested oil t-stat, no worky at all at 210 deg. Will replace that and report back. I don't think it has worked since I bought the boat, and I did not know there was a t-stat in there.
HP350SC is offline
Old 02-14-2006 | 09:45 AM
ratman's Avatar
i thought the holes in the t stat were to keep some water flowing thru the exhaust to keep it from getting too hot while the engine has the t stat closed.
ratman is offline
