F-450 or F-350/ Outerlimit's Hauler
I will be pulling an Outerlimits 42 Legacy on a triple axle Myco; some xcountry, but mostly 100 miles or so every once in a while.
Do I need to step it up to an F-450?
Will an F-350 do the job just as well?
What are the important differences between the two?
Thanks for the input.
P.S. Don't want to spend the $ for F-650 ect..
F350 is more than fine, just make sure the trailer is up to the task as well, have straps in front and rear, a few threads on here on that as well. Good luck and congrats on the OL, great boat.
Jeff
Jeff
Check the tow rating of the truck needs to be rated to pull the weight of the boat and trailer, if it isnt rated to tow your weight , your insurance could deny the claim if you ever have one, the way my policy reads required me to upsize from a F350 daully to a C4500 Top kick, not worth the chance of a court battle had I had a claim, my F350 pulled my 44MTI just fine, the C4500 doesnt hardly know its back there
i have an 04 f-450.. the piece of mind was worth every penny... i love my ride and have no worries about what it can handle nor insurance... the 450-550 have bigger rears and much bigger brakes... worth every penny if you ask me.....
I would think if you had a F350, you would need at least 4.10 rear end, but the Tow Boss version has an even higher tow rating with the 4.30 gears. I think the Tow Boss is rated for 18K.
I am in the same situation and looking for a 450 or 550, but they are hard to find... may just go with an F350 with the right gears.
From: A tree somewhere in the woods in Clarcona Fl.
Here is some info that may help your decision.
http://www.ford-trucks.com/specs/index.html
