oil coolers
Old 02-18-2006 | 04:07 PM
johnnyboatman's Avatar
Default oil coolers
i have 3by 20 coolers will they be enough to cool my oil. teague said to small but theres is 22.5inches by 3.5 inches dosent seem much bigger. im using 10 milodon pans . cp list a 25 and 28inch cooler sholud i lean towards them
johnnyboatman is offline
Old 02-19-2006 | 05:45 PM
Default Re: oil coolers
ttt
Old 02-20-2006 | 02:20 PM
Wobble's Avatar
SORE MEMBER
How much HP and what area do you run your boat in.
Wobble is offline
Old 02-20-2006 | 02:45 PM
I'd say to try the coolers you have and monitor your oil temps and then go bigger if you need to.
Griff is offline
Old 02-20-2006 | 03:54 PM
RLW
Are these combo coolers, oil and power steering or just oil?
Do you have temp data now?
Wobble's question and Griff's advice hold true.
More details.
RLW is offline
Old 02-20-2006 | 05:27 PM
Hydrocruiser's Avatar
Arrow Re: oil coolers
For 450 HP to 600 HP a 3" by 20" is suggested...
I like Hardin's dual 2" by 18" setup...personally..I know a guy who uses twin duallys...primo!
http://www.hardin-marine.com/product...il-coolers.htm
Hydrocruiser is offline
Old 02-20-2006 | 07:22 PM
850hp blown, i ordered th teagues better safe than sorry. engine builder said the one i had where a little small.after all ive been thru on this thats a drop in the bucket. and we boat on texoma.
Old 02-20-2006 | 08:56 PM
So Teagues have a 28"er and Hardin has dual 18"ers which is 36" of surface area...it's all about surface area..I think awhile back most thought the Dual 18" Hardin Marine units offered the most cooling/surface area and can be in tandem for dual 18" units with 72" of surface area...they cool really well I can tell you that and flow great! I see 'em on race boats...larger diameters means less surface to heat exchange surface area...these things can cool your oil to room temp if you desire..
Old 02-21-2006 | 09:18 AM
nordic95's Avatar
Can any one tell me if this is a stock Merc. oil cooler?Its on a 1991 502 mag. Will this cool 600 horse and if not what cooler is recommended?Should it be thermostatically controlled?
Thanks Nordic95
Attached Thumbnails oil coolers-100_0476-medium-.jpg   oil coolers-100_0477-medium-.jpg
nordic95 is offline
Old 02-21-2006 | 11:28 AM
boatman22's Avatar
Here is what I used on mine:
http://revolutionmarine.com/shopsite...ilcoolers.html
boatman22 is offline
